MY latest mod for nemesis
RE: MY latest mod for nemesis
Looks Good blackrain..Looks like a leam mean racing machine..think you might want a less weight radio and servo tray. I am working on two versions Carbon Fiber And Aluminum,, The alum. one is almost done
No The aluminum shocks are actually heavier, not by much tho(maybe a couple grams)..I dont think you could do much better than what you have. Unless of course you went to a different shock altogether but the size and stroke needed I think you have what you need..Maybe heavier springs so you dont have to compress them as much, Just My Opinion..
They are..But I was thinking about having a spring manufacturer I know build stiffer ones or progressive rate, But I wanted to get several people on board to pool money so it can be done affordably..
CT
i was thinking of cutting the red springs and the white a little and somehow joining them together. maybe making a aluminum spring holder that has a lip on top and the bottom. i think it will be easy to do just make it on the drill press.
