ct5 leaving oil streaks
NY
hello running my ct5 for about two weeks i have noticed that its been leaving oil trails on taking off and also dripping oil when stopped this is all comming outta the muffeler what can that bef rom?
RE: ct5 leaving oil streaks
Chris,
That is normanl for a nitro engines since the 2cycle fuel as oilin it for lubrication. You could tune the engine alittle leaner but you will cause overheating.. Oil and grungy nitro vehicles are the norm.
Hope this helps!!
Hope this helps!!
just lean out the engine and use 16% i have same car these engine are very strong they can be ran pretty lean without damage especily at low revs also the exhaust points down whereas most other cars point out so it wood not be noticed on other cars , also as long as u have slight ( blue ) smoke @ all rev range u cant go wrong. i use AT RACING 16%
