gst 7.7 rear brakes
PA
gst 7.7 rear brakes
has anyone had any brake problem in with there gst 7.7.. Mine just vibrated apart i cant seem to make the adjustment rod stay in know matter what i do.
RE: gst 7.7 rear brakes
Are you talking about the control rod staying in the brake lever rod hole?? if so then you will probably need to adjust the end point on the radio for the throttle servo. I have never had that problem so I'm not sure exactly what you are refering to.
BTW Stop shaking when you take your pictures...LOL
You can put one of the set screw collars at the end of the rod to keep it from pulling through the loop. I used one from a parts truck. If you use a return spring on the carb, you can use the collar that is on the end of the throttle linkage near the throttle/brake servo (the one that holds on the spring, since that spring won't be needed anymore).
