Help me build the ultimate CEN GST 7.7 basher!
KY
RE: Help me build the ultimate CEN GST 7.7 basher!
I have a nemesis 7.7 and I have put all the alum hp up parts on it.No supercharger,yet.My problem is it wants to eat spur gears and clutch bells.Anyone have any ideas?
CA
GSS22
http://www.cenracing.com/cars/genesis/parts/gss22.jpg
GSS23
http://www.cenracing.com/cars/genesis/parts/gss23.jpg
this will help your ultimate basher greatly- CNC gears!!!!!!
Call our friendly sales department 714-792-1923
or order online
www.cenracingdirect.com
GSS23
or order online
The front driveshaft in the GST is plastic, the front driveshaft in the Nemesis is steel. The center diff and diff cup reqiures the use of some spacers and extra screws, however I have heard the the newer GST's already have the bulkheads so all you will need is the front transmission, drivecups and the steel drive shaft. I order most of my CEN parts from www.customrccars.com. Give Ryan a call he will help you out and hook you up with what you need.
RI
#31
MI
the tubing roll cages will bend, this is the one i use and i have had no problems with it [link]http://r-cstore.com/store/product_info.php?cPath=21&products_id=29&osCsid=3aea21c51a43a049ebf483c521a48991[/link]
#32
Way to tall!! put COG way too high and WILL bend!!! One of the Better built, just goofy looking mounted on any o the Genesis series trucks!!! Sorry no offense intended, just been there done that!!
#33
NY
Can you guys elaborate on the dual servo mod for the GST. I see if the battery box is removed and another steering pivot is added, a servo can be placed there but does anyone make a servo mount? I was considering installing a 1/5 or 1/4 scale servo but I'd rather have 2 servos like a Revo.
No one makes the servo mount, you will have to cut it yourself unless you wanna pay me $1,000,000 and I will build you akit!!!
Seriously if you wnt one PM me and could work something out!!
#35
I'm a newby just bought my first truck gst 7.7 i repeat i am GREEEEEEEEN at this you guys sound like u know your stuff tell me any must have mods for my truck
just got it yesterday broke it in as instructed ,tuned it, the first five Min's of running took about a 3 ft high jump and broke a servo gear needless to say that sucked
any help will greatly appreciated
#36
MI
the first thing i did with mine is run it into the neighbors truck how did you break a servo? ive run mine into curbs at almost full speed, it just bounces off. if you have any questions about it email me, i would be glade to help.
#37
ORIGINAL: dakota_davies
Its actually rather easy to break a servo!! These are 15-17lb trucks (depending on how much bling you have on it) and the comparitively small, tiny, petite, rather smallish servos can and will break!! but the best part is you can get cheap($15 on ebay all day long) replacements!! if you feel the need for better steering response then you will definitely NEED dual servos!!
You might be better off seeking help in a public place to insure quality info.. Just a thought.. No offense intended Dakota_Davies
#38
i think i was trying to steer the oppasite way it hit but it wasnt a hard landing at all the servo arm was jammed into the frame but that probaly happend after the break i seen your dual servo mod dogman looks great but i dont have a lot of spare time and would like to drive the darn thing some im a welder for 20 years i know a little about metal the hub on the gear snap on the servo the metal didnt look right pitted i think it was a defect think i will try a stronger servo thanx for the info any more will be appreciated
#39
ORIGINAL: bigbama1962
#42
well installed new hitec servo wasn't the 5955 its a 565 only 133 oz. but it was free seems to be stronger than the stock one though. ran and drove good but i pop the steering arm off the ball joint [still learning the terms here] took the bolt out and put it back on probably want last long going to get another . is it normal for these things to suck down a tank of fuel in about 7-8 Min's my god my dodge diesel gets better mileage. but its a running s.o.b. gst that is any advice will be appreciated come on guys help a newbie brother out
hate to be a taker and not a giver but I'm to new to give any yet
#43
sounds like it might be running rich, but I'm not familiar with your climate. Depending on your tune, it could be normal. The 7.7 is a pig!! Has to be to haul around 16lbs the way it does!!
#44
i live in Alabama weather is usually mild i think i was running the bottom end to rich leaned it out some just ran it on the bench though try it tomorrow by the way can u hose these things off with the water its a pain cleaning the mud off by hand
#45
Ok so let me get this straight are these all the parts i need?
1. GS094 X 1PC=Brake Drive Cup
2. GS219 X 1PC=Front Propeller
3. GS029 X 1PC=Differential Drive Cup
4. GSS10 X 1PC=Heavy Duty CVS
5. GSS07 X 1PC=Aluminum Transmission
Does this sound right?
