Hawk SE Clutch Bell question
Slowly progressing my Hawk SE build project and have a question on the installation of the pre-Assembled Aluminum Clutch bell onto my new OS32.
With the Clutch Shoes tightened onto the engine crankshaft I can still get a very small movement (approx 0.25 mm) of the Clutch bell assembly up and down the crankshaft.
Is this normal ?
I've assembled them a few times as per the instructions and the Clutch is tightening all the way down onto the engine ball bearing. I've used either the M9x14 washer supplied with the kit or with the engine, but the movement is always there.
Is this normal ?
RE: Hawk SE Clutch Bell question
yeah this mis normal stebbo, this appears to be a tiny bit of end play since the length of the back of the clutch is a tiny little bit longer than from the top of the inside bearing to the one on the bottom if that makes sense, mine does the exact same thing, i've ran it this way from day one with no problems
gareth
gareth
