Hawk pro kit!!! What tools needed
GA
What tools are needed to build the hawk pro kit? Does the kit come with any kind of tools. Thanks I should be getting it wednesday!!!!!!
GA
RE: Hawk pro kit!!! What tools needed
your main tools are going to be a phillips head screw driver and some hex drivers ranging from 1.5 mm to 3.0 mm and some stander hex drivers from 1/16 to 5/64 any set of allen wrenches mectric and standerd will doo . but heres the big thing i the box there are a few shims dont toss them keep them to were you can find them later with the heli assembled see if the is any play in the main gear up an down if so you need to place a shim under the gear till it is tight . dont ask how i know [:-] but ya might need it . ask if you need help
