Hawk Pro 3d set up?
WI
Hawk Pro 3d set up?
I have the Hawk Pro 30. I use theFutaba T6EXHP radio. Im interested in setting it up for 3d flight. It came fully capable but initial set up
is for normal upright flying. I need to find out how to set up the pitch mechanically and in the pitch curve for idle up flight. The default on the radio for idle up curve is 0-25-50-75-100. I havent found any way to program it for negative pitch. Am I supposed to set pitch on
the heli mechanically so at a 50% setting on the radio it is nuetral and at 0% it is actually producing negative pitch and vice versa at 100% on the blades?
AB, CANADA
RE: Hawk Pro 3d set up?
There is a good thread here explaining it all:
http://www.rotorworks.net/showthread...4242#post14242
Be sure to read to the end, where you can see what is required is not only a linear set-up in the radio, but also one on the mechanical bits on the helicopter (servo arms, swashplate, washout arms, seesaw, flybar & flybar arms and bell mixer arms).
