Delay/Gain for Hitec HS-625MG
LA
Hello, need advice. I have a Hawk Pro, I'm useing a Hitec HS-625MG for the tail rotor. Need to find out
what to set the delay on a 401 Gyro to. And about what to set the gain to on a Futaba 6EXHP.
Any advice would be great,
Bob
Bob
RE: Delay/Gain for Hitec HS-625MG
Gain will be enough to hold the tail but not too much so that it wags, start with 50 percent and go from there.
To set delay do a full speed piro and let go hard at the end, tweak the gain up a little at a time until you get a nice stable stop, if it bounces you need more, run just as much as you need.
Start saving for a 9253 or 9254 servo you will notice a big difference.
Also MAKE SURE DS mode is OFF or that servo will last about 1 flight.
