2 question on predatore gasser
1. What headspeed should I shoor for for 3D?
2. My new heavy duty clutch behaves strage: no binding between bell and shoe when I spin it by hand, seems perfect alignment but when I pull the pull start on G-26 it catches. Is this something that will go away after it breaks in?
Thanks.
Thanks.
AB, CANADA
RE: 2 question on predatore gasser
1) I set for 1850 to 1900 for 3D, using Rotor Tech 710 3D blades - works great on my G231 powered Preddy.
2) That means that the gap between your clutch and the lining in the clutch bell is "new" tight. This should wear in with more use (10 or 20 flights).
