Ball Links Tight?
SC
Ball Links Tight?
Some of the ball links are tight on my Hawk. Do any of you sand them down, or reduce their size slightly for a looser fit? Or do you use the lubrication that Century sells?
Gary
Gary
AB, CANADA
tight balls
Put them on a ball joint, take a pair of standard pliers and gently squeeze and test for smoothness. This may take a couple of squeezes untill you get a "feel" for it. Then you can loosen them nicely in very short order.
