Replaceing main bearing
Anyone ' I'm replaceing the main gear in the hawk pro 30 , my problem is the c clamps hold in the autorotation bearing. what is the tool that would do the job or any idea's on getting it out , with out damageing it ? Thanks
WA
RE: Replaceing main bearing
The tool is called a lock ring pliar, or snap ring pliar, found at most hardware or tool shops. Some are better than others, best to approximate the size of the pins on the pliar appropriate to the size of the holes in the snap ring...
