Need Gears Set for Old Futaba Servo
Old 10-23-2010, 08:12 PM
edwarda10pilot
Default Need Gears Set for Old Futaba Servo
All:
I have a Tiger Tail 4 and I am in need of a servo gear set. The plane is Ron Chidgey's prototype TT 4 that he flew in the 1979 Nats. The final output gear (the one to which you attach the servo arm) for the retract servo has seriously worn splines (bad enough that the servo wheel slips on it). The servo is a Futaba FP S130G retract servo. I have looked at upgrading the servo to the 136G but while it is narrower than the 130G it is 1/4" longer (front to rear) and .3" shorter in height than the 130G. If I upgrade to the 136G I will have to modify the servo rails for both the retract and aileron servos (the aileron servo is an FP S130) as well as install new retract pushrods and I would like not to do this [sm=confused.gif].
So, here is my question. Does anyone out there have a gear set for the 130G (the standard 130 servo gear will not work) or do you have a new or used (in servicable condition) output gear that you will sell me?[sm=drowning.gif]. I have sent an e-mail to Futaba asking for assistance but have yet to hear from them. I have also looked on the web for help but to no avail.
Thanks in advance for taking the time to read the post.
Ed
Old 10-24-2010, 07:40 AM
PatternPilot
My Feedback: (58)
PatternPilot's Avatar
Default RE: Need Gears Set for Old Futaba Servo
you might want to get a hold of Tony Stillman at Radio South and see if he might have any old servos sitting around, or he might also know about a replacment...
Old 10-24-2010, 08:14 AM
edwarda10pilot
Scott:
Thaks a lot. I had not thought of that approach. Will do.
Ed
Old 10-25-2010, 10:18 AM
JeffH
My Feedback: (43)
I have several old Futaba gear servos at home. I will check to see if any of them are 130g's
Old 10-25-2010, 12:39 PM
edwarda10pilot
JeffH:
thanks very much. It is greatly appreciated.
Scott:
I have contacted Radio South and they are going to look thru their stuff.
If all else fails, I will just have to make the upgrade to the newer Futaba retract servo.
Thanks to all for the help,
Ed
Old 10-31-2010, 04:02 PM
MarkGrabowski
Ed, if you wind up going with a replacement servo, I have a pair of JR 703 retract servos laying around gathering dust...
Old 10-31-2010, 05:54 PM
edwarda10pilot
Mark:
Thanks very much for the offer. I have replacement retract servos (both Futaba and JR) but the replacment units are longer. I was simply trying to find a gearset for the older servo. I have talked to Tony Stillman at Radio South and he is going to try to help so I am going to send him the servo and see what can be done.
Many thanks for the offer. It is greatly appreciated
Ed
Old 11-01-2010, 10:47 AM
JeffH
My Feedback: (43)
I did check, all of mine are the 136s, they are old as they have the old FGK plug, but alas, merely a 136. No jackpot here.
Old 11-01-2010, 11:27 AM
edwarda10pilot
JeffH
Thanks for checking. I think I have tried to find a gearset match from a lot of my old Futaba servos but all to no avail. Per Tony Stillman, I am going to send it to Radio South and see if they can help.
Ed
Old 11-01-2010, 02:09 PM
dhal22
i wouldn't even hesitate, send it to the experts (radio south) and let them fix it. no further efforts required, of course assuming they have the parts.
Old 11-01-2010, 02:43 PM
roy3785
roy3785's Avatar
You have mail.
Cheers Roy.
Old 11-01-2010, 03:17 PM
edwarda10pilot
Roy:
Thanks very much. They have the gear set in stock. Have you ordered from them before and if so how was the service/shipping? Did you have any problems and if so, were they resolved to your satisfaction? Do you know in what country they are located?
Thanks very much,
Ed
Old 11-01-2010, 03:49 PM
roy3785
roy3785's Avatar
Hi Ed.
Not used them. have also sent another link looks like same people.
Cheers Roy.
Old 11-01-2010, 04:22 PM
roy3785
roy3785's Avatar
Hi Ed
More mail this should be just right.
Cheers Roy.
Old 11-01-2010, 08:22 PM
edwarda10pilot
Roy, et al:
Thanks so much. With your help I have found a set of gears for the servo.
Many thanks,
Ed
