ROSSI 61 FIRE
ROSSI 61 FIRE
Ok.. I'm just thinking about how I'm going to restore my Atlanta60. It came with a nice old Rossi 61 FIRE and matching pipe.
I pretty much know nothing of the Rossi line, so...
My question is, how good are these engines.. really? Is it worth keeping it in an Atlanta?
DM
DM
RE: ROSSI 61 FIRE
DM,
Rossi's are very strong running engines. I have a Rossi FIRE 61 in my Dalotel. See Attached pics. The Rossi pulls the plane around very well even though the plane is a bit on the heavy side with its built up fuse and sheeted foam wings. Even though your Rossi may not have the power of a YS, neither will almost anything else. I'd say try it in your Atlanta and see how you like and if you don't, then you can try a different motor.
David
David
RE: ROSSI 61 FIRE
DM
My Atalanta’s in the 80’s were powered with Rossi’s, Ballistic power.
Think of Rossi,OPS,and Picco as you would of Ferrari.
Assuming that you motor is in good mechanical shape, (probably need a set of bearings) you’ll be very surprised with the brute power if set up correctly.
It’s not an O.S. !
Just a little note about the Atlanta airframe, due to the location of the tank you might encounter flooding issues with the motor so clamping the fuel line is a must at startup and shutdown.
It’s not an O.S. !
RE: ROSSI 61 FIRE
ORIGINAL: dhal22
and i'll take the atlanta. [8D] sorry, i have no help with the rossi
If not, I think I might be able to help with you getting an Atlanta![sm=wink_smile.gif]
RE: ROSSI 61 FIRE
DM
Also take a look at this thread, might give you some more info on the Atlanta and fuel issues.
http://www.rcuniverse.com/forum/m_91...tm.htm#9263788
My Feedback: (121)
RE: ROSSI 61 FIRE
I'm a diehard OS/YS guy, but back in the BPA/classic pattern days most of the pattern guys (6-8 regular competitors) I flew with in my old club used Rossi engines. My assessment of them is that they had nearly the power of a YS with almost the ease of operation and reliability of an OS. VERY durable - Rossi engines could withstand lean runs better than any other engine I've seen. They could be flown right out of the box, but maximum power usually required an hour or so of running time.
I have a couple I plan to run... one of these days
-Will
-Will
RE: ROSSI 61 FIRE
Agree with flywilly. The 61 FIRE Rossi I am running is very reliably, easy to tune and turns a 11x8 Graupner (little wider blade a APC I would say) at 13.600 on 15% synth oil, 8% nitro and a copy of a Hatori tuned pipe. Throttle response is very instant.
I had to learn to flip start the Rossi against running direction, just to the point when compression is felt - then it kicks the prop over in running direction and starts up. Starting it the normal way resulted in 2 broken propeller trailing edges, since it kept kicking back wildly - never had this issue with my OS RF 61, Webra 61 or MVVS 61.
RE: ROSSI 61 FIRE
Hi,
I had a Rossi 61 FI RC ABC rear exhaust with pipe in a Mach 1 in 1977 and that engine had great power and was very reliable. I had servo controlled needle control on my Rossi. The pipe back then had an O-ring inside the front part of the pipe so You just slided the pipe back-forward to tune it.
RE: ROSSI 61 FIRE
I remember someone posted a chart that showed a few (4 I believe) engines and their performance on a graph. This show peak RPM prop size, etc.. awsome info.It had the Webra, OS,YS, andI think the Rossi as well. Wish I knew the name of the thread.
anyone remember that one?
DM
DM
QC, CANADA
RE: ROSSI 61 FIRE
Hey David,
good to have you back. I hadn't made the connection with your new username.
I think the chart that you are talking about might be on the Mac's pipes website. Is this it by any chance?
http://www.macspro.com/tuning.asp
Look at the bottom of the page for performance figures.
David.
David.
RE: ROSSI 61 FIRE
Thanks for the warm welcome Mr. Pappas!!
Was it my bad spelling (kind vs. find) that gave it away? lol
I have my computer in storage and all my passwords are in it... I had to make a whole new account for now. But it is nice to post again. So much new and exciting things going on right now!
DM
DM
RE: ROSSI 61 FIRE
Thanks speed panzer. That isn't the one that was posted before but wow! That looks quite informative. Can you mail me a copy?? I'd love to read that over.
[email protected]
DM
[email protected]
DM
RE: ROSSI 61 FIRE
Mails have been sent.
About this excel sheet called "Prop Power calculator" - due to lack of time I have never really investigated it, please let me know what you think about it.
Regards
Dominik
Regards
Dominik
