Look for classic pattern builder
RE: Look for classic pattern builder
Hi David,
When he posts it'll show on the "last post" counter but his message will not show up. If you go to his profile you can see that he posts regularly, but I've seen nothing on the board.
Chris...
Chris...
ORIGINAL: stuntflyr
Hi David,
When he posts it'll show on the ''last post'' counter but his message will not show up. If you go to his profile you can see that he posts regularly, but I've seen nothing on the board.
Chris...
Hi David,
Chris...
Chris,
I knew this situation was happening a few months ago but had no idea Rusty was still posting here. I assumed he had moved to the other forum completely. We correspond there regularly. can other rcu members see his posts here? might be an interesting topic.
No - no Rusty posts
I am in the NY area (Long Island) and am also looking for someone to build for me. Commuting into and back from Manhatten 2 hrs each way certainly cuts into the "me" time
I have an original Glass/Foam DB60 I would like to see fly with electric power
Any Retired good builders out there ?
ORIGINAL: Ilikebipes
BLASPHEMY!!!
Brian
BLASPHEMY!!!
Brian
surely the moderator is on our side and will remove this charlatan from the ranks.[8D] maybe we can find him a quality recording of a piped YS short stoke and he can install a some sort of sound maker for it. what's next, make it a taildragger?[X(]
#31
I build them all day every day, PPG automotive finishes, Glass work , fuses , cores .......
[email protected]
[email protected]
#32
ORIGINAL: dhal22
BLASPHEMY!!!
Brian
BLASPHEMY!!!
Brian
SMOOCHES for both of you ...
... from my bad breathed dog
#34
IL
Hi,
I am located in the Chicagoland area and have over 30 years experience building and flying RC aircraft. I have built several MK kits over the years and I would be willing to build this plane for you. I have recently painted a Dirty Birdy .60 for Rusty Dose and other pattern guys in the Chicagoland area. I am currently working on a Phoenix 8 and plan on attending Rusty's contest in May. I can get several referrals for you. I have built a couple of the .25 sized versions of the Blue Angel back in the 80's. I would also suggest maybe taking the extra time to copy the parts and try to make a couple of planes and keep the original kit intact? Just an idea. Send me a PM if you are interested. Thanks and good luck!
#38
I am currently actively moderating this forum and will spend as much time taking care of the forum. I started moderating this forum a couple of months ago and am now just getting up to speed on what has to be done here. I do not have control over what has happened in the past. RCKen is the Community Moderator and has that say-so and until I get totally up to what is going on here, I will rely on him to give me direction where needed.
In the mean time, I've been looking over Rusty's posts and have released most of the recent ones, working back in date. As I said, I do not have any say so on his situation, that is between him and RCKen. When and if that situation gets settled, I would assume that things will go back to normal.
Please be patient as I get caught up here, and thanks for understanding.
CGRetired.
CGRetired.
