Interest in carbon copies of Rev-Up 11x7.75 props
There are a couple of cottage shops that might be interested in making CF clones of out favorite props. I thought the Rev-Up 11x7 3/4 would be a good one to copy. Because I only have one!
How many people would be interested?
Chris...
Chris...
QC, CANADA
RE: Interest in carbon copies of Rev-Up 11x7.75 props
Chris,
Sure, might be interesting. A slightly wider gamut of props might be needed though. Any idea on what pricing might be like?
David.
David.
One guy makes a bunch of Rev-Up clones for the C/L Stunt guys. Raw they're 22 bucks, finished and balanced they're 32 bucks.
Chris...
Chris...
ORIGINAL: stuntflyr
Chris...
Chris...
If it's Academic curiosity.... I totally get that.
My Feedback: (92)
I never used the Rev-Up 11x7.75. I used the 11x7.5. If you actually pitch gauged a Rev-Up it was always underpitched. BTW, I have a bag of 11x7.5's if you want to copy one of those. In fact I should try one just to see how it compares to an APC 11x7.
ORIGINAL: doxilia
Chris,
how the heck does one balance a CF prop!? Can one actually sand them or are they dynamically balanced at the hub?
David.
Chris,
David.
I just sand them like any other material. It's just like a glass prop. The difference is that if you are trying to shorten one, a saw must be used.
Chris...
ORIGINAL: TonyF
I'll keep that prop in mind, Tony. I'd like to try one if you have one to spare, too.
Chris...
ORIGINAL: MTK
Just curious....why would one go through all the trouble since a perfectly fine alternative is cheap and available? APC 11x8; less noise and more thrust from the same power source
ORIGINAL: stuntflyr
Chris...
Chris...
Some guys that used those props in the 70's and 80's and still use them today, feel they're pretty good. I don't know if they are better still than modern props or not. I've just started to gather a prop collection for high rpm 60's/61's and simply am wondering about the matter.
Which engine are you using the 11x8 APC? I noticed, like Tony said, the Rev-Up's were shallower in pitch than advertised. APC's seem to be right on so your engine must be a monster.
Chris...
