If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 8 of 10 FirstFirst ... 678910 LastLast
Results 176 to 200 of 233
  1. #176
    doxilia's Avatar
    Join Date
    Apr 2008
    Montreal, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Building a Tiporare .40
    Chino,
    good to see you at it again. She will be done very soon now.
    I came across some pictures that were sent to me of a Tipo 40 that was made and sold by WK Hobbies - the original maker of the Tipo 60 glass fuses. The pictures are from a fellow modeller who had a kit and built it. He actually started a thread here on RCU but I have been unable to locate it. The specs of the glass/foam model are very similar to my reduced scale T40. You can see that the rudder and elevators on the WK is slightly different from the reduced T40.
    I thought you might enjoy seeing them. The model was finished in paint throughout.
    David
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1738394   Click image for larger version.
  2. #177
    Join Date
    Jun 2010
    Buenos Aires, ARGENTINA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi David! Iwas on vacations and traveled to USA… and got some stuff from TowerHobbies!>>
    Nice model and finishing… the stab´s wing tip isn´t the same. I´d like to know which is it´s>>
    weight.>>
    Now my problem is that I´ve to apply clear urethane to the fuse and do not have air compressor!!!!The one that I used from my father in law is 200 miles away!!!>>
    So I can apply Monokote but not the finishing coat… I´ll see.>>
    By,>>
    Chino>>
  3. #178
    doxilia's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chino,
    We're you able to look into SprayMax availability in BA?
    You could have stuffed 2-3 cans in your luggage when in the US but I guess it doesn't help much to mention it now.
    Find yourself a buddy at your flying club who paints... Or just take the fuse to an auto painter and have them shoot it.
    David
  4. #179
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes... I´m working in an alternative. Thanks!
  5. #180
    Join Date
    Mar 2006
    Lebanon, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    David, that is my WK Tipo 40 that you showed in the pictures, I think the thread you may be looking for was the one where you were scaling the plans, and I added the pictures of my plane. Chino, very nice job, I have been following the progress Ed
  6. #181
    Join Date
    Mar 2006
    Lebanon, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    David, the thread was Tiporare and Super Tigre 45 from Jan 2011
  7. #182
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you epr3!
    Which is the weight of your Tipo .40?
  8. #183
    Join Date
    Mar 2006
    Lebanon, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chino, I have not completed the plane, but I think I calculated it to be around 5.5 to 6 lpounds.
  9. #184
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I´m trying to get 5.5 pounds too.>>
    Thank you.>>
  10. #185
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Covering the bottom wing and stab.
    Will continue...
  11. #186
    doxilia's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice work Chino.
    If you have the patience to cover your wells more power to you, otherwise I recommend flat black paint. You could use something like Rustoleum or the like. Enamel is preferable to lacquer here as it flows on with a little smoothness.
    Looks like she'll be ready for the fall!
    David
  12. #187
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi David!>>
    I´ll paint them.>>
    I think that I´ll finish theplane in a few weeks but I´ve to solve the CC to the fuse. >>
  13. #188
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is how the Tipo will look from the bottom:
  14. #189
    doxilia's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool!
    How will it look from the top...?
    BTW, it is probably an optical illusion but it looks like the main gear is ahead of the CG. I'm sure you installed it per plans.
    David
  15. #190
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes!!! I´ll check it, but the main LG is in line with the CG. I don´t know if this is correct....
  16. #191
    doxilia's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chino,
    Not inline, just aft. If you put her on her legs and pull the tail down to the ground, dry, it should stay there. Of course, it should also sit on all three's if just put down. When wet, she'll definitely pop back on to the nose gear if you pull the tail down.
    The idea is that you can "flare" her on to the mains as she lands and will drop on to the nose gear even when she's empty.
    David
  17. #192
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, understood!!!
  18. #193
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Will continue...
  19. #194
    alcarafa's Avatar
    Join Date
    Dec 2006
    MEXICO, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: chino_2005
    Ok, understood!!!
    Chino your plane is looking great , keep it up ! ( sos grande pibe ! )
    Rafa.
  20. #195
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gracias Alcarafa!!!
    I hope it flies better than it looks!
    Saludos!
  21. #196
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Will continue...
  22. #197
    Join Date
    Oct 2008
    CheltenhamGloucestershire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well done Chino. Inspiring. Must get on with covering my model!
    Kenneth
  23. #198
    dphill2's Avatar
    Join Date
    Dec 2008
    Hueytown, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great looking Airplane Chino. Makes me want to drag out the 40 size I have in the shop, and bring it back to life !
    I'm building a 60 size right now and in the primer stage. hope to have it ready to fly in compition this year ..
    Keep up the fine photos of your work !!
    Dave
  24. #199
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you for your comments!!!
  25. #200
    Join Date
    Jun 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally... the rudder!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
