Name This Plane
Old 01-23-2012, 04:56 PM
Zero
My Feedback: (42)
Zero's Avatar
Default Name This Plane
I recently purchased the pattern plane shown in the pictures below at a swap meet. It has a wingspan of 64” and the fuselage is 47 ½” long without the rudder. The wing area also calculates out to 600 sq. inches. I would estimate that the plane will end up weighing approximately 9 lbs. which would give the plane a wing loading of approximately 34.95 oz/sq. ft. The plane has not been finished. The seller told me that his brother built the plane. He did not know anything else about the plane. I would like to ask if someone might be able to help me identify this plane. I want to finish it and need to know about the dihedral & CG as well as any other important facts. The fuselage is fiberglass and it is scribed on both sides for the horizontal stabs. I do not know if I need to join the stab halves and cut out the fuselage or simply insert dowels thru the fuselage and attach the stabs. There are marks where this might work but I don’t know. The stabs are foam sheeted with balsa. The wings are foam sheeted with 1/32” ply. The builder did a great job on the wings. I am not sure about the tips on the stabs. I think that the tips are not correct.
Thanks to all.
Fred
ID:	1717710   Click image for larger version
ID:	1717711   Click image for larger version
ID:	1717712   Click image for larger version
Old 01-23-2012, 10:13 PM
dave pattern
Default RE: Name This Plane
that is definitely a super cuda from better built models in cammarillo california
if you might be interested in selling it pm me
Dave
they look like this
Old 01-24-2012, 11:18 AM
KLXMASTER14
KLXMASTER14's Avatar
+1 super Cuda
