Dirty Birdy ARF
Reply
Old 07-31-2012, 03:38 PM
  #601
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dirty Birdy ARF
Ralph,
I use a torch to heat it up until it’s easily bendable.
I use metal bars inside and or on the outside of the tubing to make it bend.
I use oak hardwood pieces with a bored hole to clamp in the vise as not to mar the header.
Here are the two torches that I use; if you’re not careful with the heat from the torches you can melt the aluminum.
I have on occasion ruined a header or twousingthis process ............................
Quote:
ORIGINAL: Ralph White
Paul, How did you go about re-bending the header? I was afraid the header might kink if I tried re-bending it.
Ralph White
ID:	1787971   Click image for larger version
pitstop000 is offline
Old 07-31-2012, 03:52 PM
  #602
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, the header ends up being too close to the fuse so I needed to tweak it so the pipe could be mounted on the side of the fuse.
I put in a balsa block and contoured it for the header fit, then glassed over that. I also contoured the back of the block so you can still fit the stock tank,
but I’m using a 2 oz tank in the location of the stock tank with a 16oz behind that. The NovaRossi 61 is a very thirsty engine when running high rpm.
Quote:
ORIGINAL: Strega1
Hey Paul
Thanks for the pics and the info on the DB and Rossi. I'm at a loss on the header. Why did you have to bend it? Was there an obstruction? Does all this grinding weaken the firewal? How are you going to reinforce it and with what? When you are done with this project, please furnish more pics and a blow by blow on how you did this particular cut to the firewall. I'll be doing the same with my project, either the side exhaust w/ Performance Specialties tune muffler, or the RE Rossi and modifications. I'll furnish plenty of photos
Thanks for all the info and the photos.
Ben Cubillos
El Paso, Texas
ID:	1787975   Click image for larger version
Old 07-31-2012, 03:57 PM
  #603
PatternPilot
PatternPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
Looks good..... with the header tank are you going to put the main tank on the CG ?
scott
PatternPilot is offline
Old 08-02-2012, 09:59 AM
  #604
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott, I’m still working out my fuel system on the Test stand, but aiming to put the 16 oz close to the CG if possible with my setup.
“HEADER UPDATE”
Even after tweaking the stock NovaRossi header, the clearance that I was looking for could not be achieved, so I cut the exhaust flange off a strait header and bent a new pipe and welded it together. Now I’m back in business, just need to clean up the weld and polish her up. Everything good to go as far as the exhaust.
Old 08-02-2012, 07:59 PM
  #605
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
header done!!, this has put me behind schedule but worth the power the NOVAROSSI 61produces
Old 08-03-2012, 04:30 AM
  #606
JeffH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you TIG the header together?
JeffH is offline
Old 08-03-2012, 06:01 AM
  #607
PatternPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks like paul is going into the header bussiness.....
Old 08-03-2012, 11:21 AM
  #608
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, more pics of the glassing and how it turned out before paint.
It came out better than I thought for working with a painted fuse, TAPE is your friend!!
I used UFO thin and some accelerator to do the glassing instead of epoxy, very quick and light process.
Quote:
ORIGINAL: Strega1
Hey Paul
Ben Cubillos
El Paso, Texas
ID:	1788512   Click image for larger version
ID:	1788513   Click image for larger version
ID:	1788514   Click image for larger version
Old 08-03-2012, 06:33 PM
  #609
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Jeff,
Yes this one was done by Heli Arch/TIG, but I’ve also done them with the aluminum welding rods.
Quote:
ORIGINAL: JeffH
Scott, need a lot more equipment for such an endeavor.
I can do them if I run out of options.
I just need a more precision bender which I finally have found though.
Quote:
ORIGINAL: PatternPilot
Old 08-05-2012, 07:07 AM
  #610
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NovaRossi REX CX61 installation pics.
ID:	1789266   Click image for larger version
ID:	1789267   Click image for larger version
ID:	1789268   Click image for larger version
Old 08-05-2012, 08:09 AM
  #611
Harv2828
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have flown my Phoenix 7 arf with the 65 OS and standard muffler. Today's engines are so much better that I really don't think I need a tuned pipe. Goes fast and flys great with eflite electric retracts.
Harv2828 is offline
Old 08-05-2012, 08:23 AM
  #612
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pitstop000
Very nice setup!!! I wish I still Had my Rossi CX61.[]
Have fun and we want a flight report, please!!
Sonny
aka
jet22b
jet22b is offline
Old 08-05-2012, 08:36 AM
  #613
Ralph White
Ralph White's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, What ball links are you using on the throttle and mixture controls at the engine end? How are they connected to the cables?
Ralph
Ralph White is offline
Old 08-05-2012, 11:34 AM
  #614
landeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Harv2828
Harv, how did you mount the E-Flite nose gear? I have read that people were having problems with the gear electronics failing because of vibration.
Bruce
landeck is offline
Old 08-05-2012, 11:37 AM
  #615
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Sonny,
"Flight Report" sure, that's comming up.
This NovaRossi DB and the otherOS powered DB will both be at the NECPO event onSept 8, 2012 in
Farmington CT
Any qualified pilot will have a chance to fly either one at the event.
Quote:
ORIGINAL: jet22b
pitstop000
Sonny
aka
jet22b
Ralph, I used Sullivan's #508 flexible cable which includes the brass couplers with 2-56 threads, just silver solder them on and they fit the ball links.
For the Ball links I use the Dubro 181 for the trotle and the Dubro 190 on the mixture control, they also come with solder on 2-56 couplers.
Ralph
Old 08-05-2012, 11:51 AM
  #616
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FINALLY DONE !! More pics Guys.
ID:	1789373   Click image for larger version
ID:	1789374   Click image for larger version
ID:	1789375   Click image for larger version
Old 08-05-2012, 12:23 PM
  #617
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Again, very sweet setup!! Thanks for sharing!!
Sonny
aka
jet22b
jet22b is offline
Old 08-05-2012, 05:04 PM
  #618
AllTheGoodNamesAreTaken
AllTheGoodNamesAreTaken's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul, that looks fantastic!!!
AllTheGoodNamesAreTaken is offline
Old 08-05-2012, 07:55 PM
  #619
KLXMASTER14
KLXMASTER14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
Buckle up buddy! That thing is going to haul *****!! I had the opportunity to fly a ten pounder with the NovaRossi up front. Didn't feel like ten pounds to me. Best of luck on your maiden. Very clean job, by the way.
-Robert
KLXMASTER14 is offline
Old 08-06-2012, 08:31 AM
  #620
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Pitstop000,
You have INCREDIBLE skills..... How are you going to attach the pipe to the fuse for support, or are you?
David
hrrcflyer is offline
Old 08-06-2012, 10:35 AM
  #621
Gene Margiotti
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
What spinner are you using?
Thanks, Gene
Gene Margiotti is offline
Old 08-06-2012, 02:18 PM
  #622
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Guys for all the compliments!
“Pipe mount”
I’m using a regular DaveBrown tune pipe mount, not the Hush-clamp, I don’t trust O rings for retaining a pipe and rather strap it with a metal zip tie.
“Spinner”
Custom moded 2 ¼ Tru-Turn FAI spinner.
Here are some pics of the OS 65 AX powered Dirty Birdy, “BD 1”
ID:	1789797   Click image for larger version
ID:	1789798   Click image for larger version
ID:	1789799   Click image for larger version
ID:	1789800   Click image for larger version
ID:	1789801   Click image for larger version
Old 08-06-2012, 08:50 PM
  #623
jet22b
jet22b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
pitstop000,
Another sweet setup!!! Can I come and hangout in your worshop??? Now that I see how the OS 65AX look in this bird, I will have to make the move get get DB #2, ( when Tower get them back in-stock,), I will go with that setup. I just my buy two DB's and set up #3 with the Evo 60nx with a Jett pipe. I have that setup in a Hangar 9 Jackal and its a blast!!!
Thanks, again for sharing!!!
Sonny
aka
jet22b
jet22b is offline
Old 08-07-2012, 07:02 PM
  #624
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anytime Bud!
Quote:
ORIGINAL: jet22b
pitstop000,
Sonny
aka
jet22b
Old 08-08-2012, 06:34 PM
  #625
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Going back to wing joiner, forgot to post this at the time.
Here are pics of it all done, used G-flex epoxy for putting it together. One to one by volume or 1.1 to 1 by weight, this epoxy can take flex without cracking like other epoxies once stressed. This was the heavier of the 2 wing joiners so it went into the OS powered Dirty Birdy.
ID:	1790390   Click image for larger version
Reply
Display Modes
