Bootlegger?
Reply
Old 01-29-2013, 03:08 PM
  #126
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bootlegger?
Thanks Paul,
I guess that may be why the Ex Port is lower in the cylinder than the other long rod motors !! The part I don't understand is the piston speed in a long rod will be higher than in a short rod turning the same RPM !!
You would think they would work out the torque and HP curve to come in @ a lower RPM because of the excess Piston speed..
Anyway I'm going OLD SCHOOL now where did I put them 11X7
Dave..
dphill2 is offline
Old 01-29-2013, 03:49 PM
  #127
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the latest on my project ! I test fit all the formers and made sure the fiberglass top would work out !!
One thing I found out with the balsa fuse side being a stright line from the top of the firewall back to the tail, I had to cut a strip off the fiberglass piece to lower it so it would match the plans. The strip is 3/8" at the front and 5/8" @ the rear. Worked out fine ..
Dave...
dphill2 is offline
Old 01-29-2013, 05:21 PM
  #128
pitstop000
pitstop000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave Looking Good!
I’m just wondering is the fiberglass top to become a permanent part of the fuse? or will it be removable.
pitstop000 is offline
Old 01-29-2013, 05:22 PM
  #129
tgwhitley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
I may stop the Typhoon just to build my bootlegger looks great keep posting progress
Tim
tgwhitley is offline
Old 01-29-2013, 05:24 PM
  #130
PatternPilot
PatternPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks good... wish I had a fiberglass deck... [] []
PatternPilot is offline
Old 01-29-2013, 08:13 PM
  #131
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
I have thought about making it removable but the plan was to make it permanent !! What do you guys think ???
Dave...
dphill2 is offline
Old 01-30-2013, 07:46 AM
  #132
doxilia
doxilia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I gave that one a thought too. While having a removable top Arrow style is certainly more practical, it is not quite as elegant as the single fuse.
The main issue I see if making it a single piece fuse is the finish required to the fuse before permanently attaching the deck to it. I suppose there is a way to install the deck as if it were going to be removable (i.e., with some strips down the side top of the fuse to anchor the deck to), tack glue it, sand the job to uniformity, glass the wood and they paint the items separately so one can also finish the fuse area where the deck goes. The only drawback is that the seam would be visible if bonding after paint.
I suppose the alternative would be to finish the fuse interior area before final finish of the exterior so that the deck can be permanently attached and finished together with the fuse. This might be a better option so that the fuse is well blended in finish.
What do you think Dave?
David
doxilia is offline
Old 01-30-2013, 08:16 AM
  #133
PatternPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make it one piece.. less chance for flexing and twisting, plus a much better finish for the plane and you can blend it in and make it seamless.
just my 2 cents if i was building one...
s.
Old 01-30-2013, 08:25 AM
  #134
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guy's,
I think I'm going to make is as close to the orignal Bootlegger as I can !! David a one piece fuse would look as you put it " more elegant" than two piece with a seam showing . I use a product called Aero lite from Aircraft Spruce Co. (its a two part epoxy filler) This stuff is as strong as any product you can buy to fill gaps and seams !! It sands like chalk and is very lite, makes great fillets around the wing,stab and rudder also.. I'm looking forward to blending the top piece in to the balsa sides .
So I guess you have my answer !!
Dave..
dphill2 is offline
Old 01-30-2013, 08:50 AM
  #135
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got most of the major parts done and need to start assembly !!
Dave
dphill2 is offline
Old 02-05-2013, 06:50 PM
  #136
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guy's
Here is the latest on the legger !! Its all framed up and glued together the formers worked out fine after a little adj ! I built the fuse upside down using the stright edge on the top of the sides. After glueing it all together I turned it over in the jig dropped the fiberglas top on and it fit like glove !!! More to come ...
Dave.
ID:	1848630   Click image for larger version
dphill2 is offline
Old 02-08-2013, 10:02 AM
  #137
toddblose
toddblose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just found 2 OS 61 VF's so I have ordered the Bootlegger from Don at RCair so I will start on it in the next 2 weeks. I plan on building it with the flat stab
and Steve's scheme
toddblose is offline
Old 02-08-2013, 03:50 PM
  #138
dphill2
dphill2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Thats great Todd, Glad you found the VF 61's !! Keep in touch on your build when you get started !!
I orded a belly pan for My Southern RC fiberglass Boot from RCaiir and the thing fit just like the orignal.
Dave..
dphill2 is offline
Old 10-17-2013, 09:21 AM
  #139
Arrowair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am UK based and about to start the build of a Bootlegger enlarged by 10% for a K&B 100 r/e. The plan I have shows a 0/0/0 set up for thrustline/wing/tail incidence and no side thrust. Is this correct please?
Arrowair is offline
Reply
Display Modes
