Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > Classic RC Pattern Flying
Reload this Page >
Futaba FP-8SSAP Single Stick Transmitter 2.4GHz Conversion- Success!!
Old 01-16-2014, 07:18 PM
ohnas
Sorry- I'm still here. I changed my email address and wasn't paying attention to this page. My email is correct now so I will get questions.
Old 01-05-2015, 03:25 PM
mikemscott
single stick 8ssap conversion, PLEASE ANYONE OUT THERE KNOW HOW TO GET AHOLD OF OHNAS BY EMAIL, VERY IMPORTANT THANK YOU, [email protected], MY NAME mIKE sCOTT
Old 03-17-2016, 02:09 PM
Levels87
Ohnas. Could you please say what transistor you used on the PPM board output to invert the signal.
Old 03-21-2016, 04:31 PM
grotto2
grotto2's Avatar
It shouldn't be that critical, Levels.
There's an inverter diagram here.
A 2N3904 or 2N2222 would also work fine.
Old 03-22-2016, 09:28 AM
Levels87
Thanks for the reply Grotto2. I am currently struggling to get any output from the 118GP decoder board. I Have connected positive 5v and ground as can be seen in the picture from ohnas with the signal (shown in the picture earlier as PPM/PCM) pin from the tx module socket to the DSC input of the receiver. The orange from the receiver board is not connected to anything. I am only getting 1v at the PWM outputs so I tried connecting the orange PWM + to +5v as well but no luck. Any thoughts what I am doing wrong? The decoder board is confirmed to be working when I connect it back onto the receiver board.
Old 03-25-2016, 07:32 PM
  #31
grotto2
grotto2's Avatar
Levels-
Maybe put the decoder back on the receiver and scope a couple of points. Orange may be a +3V regulator output that supplies voltage from the decoder board to the receiver board. Yellow may not want a voltage higher than 3V from the receiver....Whatever it wants you must duplicate it. Any chance your DSC is dead?
Old 04-09-2016, 07:24 AM
  #32
Levels87
Well I am delighted to say I have now got this working fine. The problem I had was that the signal for the module needs to be a positive pulse and I was getting a negative one to start with. That caused me to have alternating red and green LEDs on the module. I have built a signal inverter on breadboard and combined it with the voltage dropper for neatness which sorted the problem. I was also using the signal output for the module to feed the decoder board when I should have been using the DSC output instead.
At the moment you can change between PPM and PCM512 by just swapping over the plug to the module input. The single wire is for PCM and the three wires for PPM as the + and - are required to power the decoder and converter. I am going to make one further change to make it switchable between PCM512 and PPM by putting a switch in the back where the CCPM switch would have been fitted if they had decided to go ahead with that option. Here are some pictures.
ID:	2156513   Click image for larger version
ID:	2156514   Click image for larger version
ID:	2156515   Click image for larger version
ID:	2156516   Click image for larger version
ID:	2156517   Click image for larger version
ID:	2156518   Click image for larger version
ID:	2156519   Click image for larger version
ID:	2156521   Click image for larger version
ID:	2156522   Click image for larger version
ID:	2156523   Click image for larger version
ID:	2156524   Click image for larger version
ID:	2156525   Click image for larger version
ID:	2156526   Click image for larger version
ID:	2156527   Click image for larger version
ID:	2156529   Click image for larger version
ID:	2156530   Click image for larger version
ID:	2156531   Click image for larger version
ID:	2156532   Click image for larger version
Old 05-06-2016, 04:58 AM
  #33
vic101
Great work!
Please post a picture showing the DSC source on the transmitter, that's the only missing step for me..
I'm using a JR module so I don't need to invert the signal.
Thanks in advance.
Vic
Old 05-06-2016, 05:21 AM
  #34
vic101
Ah, wait,
I see that you have already posted this - apologies, I'm doing this as a monkey-see monkey-do method.
Thanks for your and the OP's help, I'm rushing off to do some soldering!
Old 05-07-2016, 10:02 AM
  #35
Levels87
Just to make it clearer here is another picture.
Old 05-08-2016, 05:18 PM
  #36
dhal22
Way above my head. Nice work guys.
Old 05-14-2016, 09:59 PM
  #37
vic101
Perfect, thanks again!
Vic
Old 07-05-2017, 05:16 PM
  #38
Rockbud
Default Legacy FP-T8SSH-P Futaba Single Stick 2.4GHz Conversion
Vic
Not sure if this old thread is still active, but I am attempting the same retrofit on my Futaba Single stick radio. I have acquired all of the parts with the exception of the transistors, and could use some help in their wiring. Both ohnas and Levels 87 have provided some great pictures, but I'm still at a loss for the transistor connections. Any help would be immensely appreciated.
Regards,
Rick
Old 07-06-2017, 01:06 AM
  #39
Levels87
Hi Rick. I am rather pushed for time at the moment but will draw you a diagram of the signal inverter/voltage regulator as soon as I have time. It is all pretty straight forward and can be made on a small piece of breadboard.
Regards Jonathan
Old 07-07-2017, 07:14 AM
  #40
Rockbud
Jonathan,
Thank you Sir! and please take your time. My project is just getting started. Also, with only PCM 512 to start with, have you encountered any issues with stick resolution? The Futaba single stick was my first radio, expensive too for 1990. I fell in love with it immediately for flying helicopters and believe it may do justice for todays quadcopter.
Thanks again for you efforts on this.
Rick
Old 07-29-2017, 08:08 AM
  #41
joeytowmotor
I have been collecting these transmitters for many years. I will convert one of them soon. You did a fine job on yours! Thanks and fly safely.
Old 08-13-2017, 04:17 AM
  #42
dhal22
I have one nib but have never used it.
Old 04-22-2019, 12:05 AM
  #43
Levels87
Since doing this project I have come across a much better solution for the signal inverter. They are made by Tarot and sold as SBus converters for their gyro systems and they are really tiny and cheap.
Here is a link to buy one
https://www.ebay.co.uk/itm/Tarot-ZYX...637a%7Ciid%3A1
Old 04-22-2019, 02:29 AM
  #44
dhal22
Nice. Thanks a lot.
