Atlanta
Reply
Old 09-29-2012, 02:45 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Atlanta
Does the Atlanta use an offset header or what other pattern planes use the off set to go around the nose gear reason im asking I just came across I believe is an Atlanta but not sure and he has a Summit 1 too said he would take 100 bucks for both of them has YS that is seized and what looks like MK retracts
jetmech43 is offline
Old 09-29-2012, 04:08 PM
flywilly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Yes, the Atlanta uses an offset header. I believe the Hatori Aurora or Cosmos header may be very close, the problem may be the amount of 'drop' as the Atlanta had a very tight fitting belly pan compared to the Aurora or Cosmos.
flywilly is offline
Old 09-29-2012, 05:04 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
ok thanks though t it was an Atlanta, its in pretty good shape, does any one have parts for a YS I can clean the engine to get it unseized but not sure if the check valve will be serviceable
Old 09-29-2012, 05:05 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
when I get them I will post some pics would any body be interested in the Summit?
Old 09-30-2012, 09:41 AM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
ok got the plane and the wing not to good shape going to try and repair it, does anybody have an Atlanta wing they dont need
Old 09-30-2012, 10:37 AM
PatternPilot
PatternPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
sent you a pm
PatternPilot is offline
Old 09-30-2012, 10:46 AM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
sent you one back
Old 09-30-2012, 11:48 AM
rv7driver
rv7driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Heres a Pic of my Atlanta showing the Header with a YS 2 stroke. Pete
rv7driver is offline
Old 09-30-2012, 12:18 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
yeap just like the one I got
Old 09-30-2012, 01:17 PM
PatternPilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
jetmech43
sent you info you wanted....
scott
Old 09-30-2012, 01:46 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
sent you the info you wanted
Old 09-30-2012, 01:48 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
looks like your header bolts are backing out
Old 09-30-2012, 01:49 PM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Of course Don can mail you a wing core set in the morning. Mine set was very well cut. No need to wait months and months from other providers.
dhal22 is offline
Old 09-30-2012, 01:51 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
repairing wing on it now not as bad as I thought, got the engine apart now piston looks good dont know about the bearing yet im sure it will need new ones its a YS 60 FR as it says on the case
Old 09-30-2012, 02:42 PM
stuntflyr
stuntflyr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Quote:
ORIGINAL: dhal22
Original templates?
LOL.
Chris...
stuntflyr is offline
Old 09-30-2012, 02:58 PM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Quote:
ORIGINAL: dhal22
who be Don
Old 09-30-2012, 04:54 PM
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Hey Jetmech43,
Don goes by Frequent Flyer, here on RCU. He is making quite a few classic pattern planes available for us, including the Atlanta. His craftsmanship is outstanding.
Good luck with your Atlanta.
David
hrrcflyer is offline
Old 09-30-2012, 07:05 PM
Atlanta 60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Pictures Please!!!
You should be able to get a YS check valve from YS Parts and Service (pn: YS0405)
http://www.ysengines.net/support/parts/
Since you have it apart I would (personally) put a set of bearings in it...
A little problem with the YS60 is that the gasket sets are not available any more so you will more than likely have to make your own, unless you can find someone has a set laying around...Not that big of a deal though...Good thing is the diaphragm, spring, plunger, needle valve/seat and carb o-rings are still available...I'd personally order a set of those and replace everything while I had it tore down...
I attached a copy of the manual in case you need it...
Good Luck with your Atlanta!!!
File Type: pdf
Atlanta 60 is offline
Old 09-30-2012, 07:30 PM
rv7driver
rv7driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Chuck, thanks for the info will order parts for a couple that need TLC. phone # is 775-267-9252 for YS parts and service. Pete
Old 10-01-2012, 01:11 AM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
ok thanks
Old 10-01-2012, 02:55 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Quote:
ORIGINAL: stuntflyr
Original templates?
LOL.
Chris...
Exactly..............................
dhal22 is offline
Old 10-01-2012, 02:57 AM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Chuck, great to see you back on the forum. It figures an Atlanta would be the thread.
dhal22 is offline
Old 10-01-2012, 07:09 AM
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Quote:
ORIGINAL: dhal22
Dhall22,
I had to laugh out loud when I read your comment. I was thinking the exact same thing as I read Chuck's post. I guess great minds think alike..............
Hey Chuck, it is great to see you back in the Classic Pattern Forum, Buddy.
Jetmech43,
By all means, please post some pictures. An Atlanta in almost any condition is a thing of beauty.
David
Old 10-01-2012, 07:29 AM
80sPattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Quote:
ORIGINAL: hrrcflyer
David
Jet,
Here is a little motivation for you.
Doug
80sPattern is offline
Old 10-01-2012, 07:39 AM
KaP2011
KaP2011's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Atlanta
Wow! That is a beautiful plane.
KaP2011 is offline
Reply
Display Modes
