Summit 1
Reply
Old 11-06-2012, 03:55 AM
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Summit 1
I came across an old Summit that has a missing wing tube anyone know where I can get one and what size it is?
jetmech43 is offline
Old 11-06-2012, 07:49 AM
doxilia
doxilia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Summit 1
The wing itself should tell you I'd imagine. If it's built, just measure the diameter of the sleeve in the panels and you can pick up an appropriate diameter CF tube. By inserting a straight pushrod, into the sleeve, you'll also get the required length in each panel. Add the fuse center portion and you can cut the tube to length. There are several sources for CF tubes none of which come to mind now... (Take it back, maybe Budd engineering but there are much larger and varied sources.)
David
doxilia is offline
Old 11-10-2012, 05:47 AM
motoman11
motoman11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can thin wall aluminum tubing from McMaster Carr in many sizes and lengthes thats where i got mine
motoman11 is offline
Old 11-10-2012, 05:50 AM
PatternPilot
PatternPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is a place for tubes... all types...
http://www.tntlandinggear.com/
PatternPilot is offline
Reply
Display Modes
