Skylark 56 – 1966 Flashback - Build
Reply
Old 01-22-2013, 02:41 PM
  #101
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Skylark 56 – 1966 Flashback - Build
The 1/4” X 1/6” rib cap strips are installed, top and bottom. It is interesting how much strength the cap strips add to the ribs. Sanding the trailing edge basswood down to a fine 1/6” edge and blending in with the sheeting. Added some triangle pieces to strengthen gear block mounting and test fitting the main gear strut.
To be continued…
8178 is offline
Old 01-24-2013, 05:36 PM
  #102
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on the wingtip block. I use the round loop X-acto router blade to carve out the block.
To be continued…
ID:	1843956   Click image for larger version
ID:	1843957   Click image for larger version
8178 is offline
Old 01-26-2013, 12:36 PM
  #103
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on the aileron. In these images the aileron line has been cut in the sheeting and part way into the ribs with an X-acto knife.
To be continued…
ID:	1844544   Click image for larger version
8178 is offline
Old 01-26-2013, 12:39 PM
  #104
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Using a very thin fine tooth hobby saw I cut through the ribs.
To be continued…
ID:	1844546   Click image for larger version
ID:	1844547   Click image for larger version
8178 is offline
Old 01-26-2013, 12:41 PM
  #105
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I/16” sheet glued to the back edge of the wing.
To be continued…
8178 is offline
Old 01-26-2013, 12:45 PM
  #106
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aileron cut away from the center wing part and the aileron torque tube linkage. The aileron torque tube is an unused part from my Tiporare kit.
To be continued…
8178 is offline
Old 01-26-2013, 01:53 PM
  #107
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After cutting out the aileron the wing was ready for the tip block.
To be continued…
8178 is offline
Old 01-26-2013, 01:57 PM
  #108
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The back edge of the wing sanded out.
To be continued…
8178 is offline
Old 01-26-2013, 02:43 PM
  #109
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing tip block sanded out smooth with the wing.
To be continued…
8178 is offline
Old 01-26-2013, 05:02 PM
  #110
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Test fitting the aileron linkage. The nearest bay to the center of the wing on the trailing edge is filled with a balsa wedge. The extra balsa will be part of the nylon bolt mount for the back of the wing.
To be continued…
ID:	1844669   Click image for larger version
8178 is offline
Old 01-26-2013, 05:13 PM
  #111
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The torque tube is countersunk into the trailing edge to get its center of rotation as near as possible to the hinge line and epoxied in place.
To be continued…
8178 is offline
Old 01-26-2013, 07:17 PM
  #112
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The front 5/16" of the aileron was cut off and a ¼” piece added and then beveled on the top and bottom.
1/16” was cut off the front of the center tailing edge and was glued back on with a combination of glue. Epoxy glue was used where the ribs support the torque tube and yellow glue at the sheeting seams.
To be continued…
ID:	1844699   Click image for larger version
ID:	1844700   Click image for larger version
8178 is offline
Old 01-26-2013, 07:18 PM
  #113
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A brass tube gizmo was made and soldered to aileron linkage for the clevis connection.
To be continued…
8178 is offline
Old 01-26-2013, 08:52 PM
  #114
KLXMASTER14
KLXMASTER14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ultra sweet!!!!!
-Robert
KLXMASTER14 is offline
Old 01-27-2013, 11:20 AM
  #115
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The top center sheeting is on. So far so good and it is building straight and true.
To be continued…
ID:	1844931   Click image for larger version
8178 is offline
Old 01-27-2013, 11:22 AM
  #116
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I’m leaving the bottom sheeting off until I finish the left wing so I have access for measurements if needed.
To be continued…
8178 is offline
Old 01-27-2013, 11:26 AM
  #117
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: KLXMASTER14
Ultra sweet!!!!!
-Robert
Thanks Robert. It is much fun! I haven’t used the cut out aileron process on a built up wing in decades but it seems to be going fine.
8178 is offline
Old 01-27-2013, 02:34 PM
  #118
doxilia
doxilia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 8178
... but it seems to be going fine.
Mike,
When you're at the helm, it always does.
If you were to make a mistake, we would never know unless you told us.
I think I'm going to have to get me one of them balsa colored carpets..., your pictures always look great!
Can't wait to see the fuse.
David
doxilia is offline
Old 01-28-2013, 02:08 PM
  #119
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here we go again! The left wing panel top front sheeting.
To be continued…
8178 is offline
Old 01-28-2013, 02:14 PM
  #120
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: doxilia
Quote:
ORIGINAL: 8178
Mike,
David
Thanks for the comments David. I did almost glue one of the plywood gear mount doublers to the wrong rib but I caught it right away and got the epoxy off the rib! If you see me building two right wing panels let me know right away.
I’m looking forward to the fuselage too. I have the wood and I’m just thinking through if I want to use the G-21 46 or one of my more powerful engines.
8178 is offline
Old 01-28-2013, 11:04 PM
  #121
doxilia
doxilia's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 8178
Mike,
Glad you told us. It makes me feel a little more human. I managed to leave a stab setting with epoxy while I went to pick up my kid from school. Naturally I was late as "it always takes longer" when you're building. Needless to say, when I came back, I wasn't too happy with what I saw... But that was a while ago.
We will..., in the extremely unlikely event!
What are the other options? Knowing how you like to set things up, I wouldn't be surprised if we wind up seeing a 55 up there.
This thread is just cookin'! You're making excellent progress.
David
doxilia is offline
Old 01-29-2013, 10:46 AM
  #122
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Added the lower front and tailing edge sheeting. Epoxied in the landing gear block plywood rib dubblers and gear block.
To be continued…
8178 is offline
Old 01-29-2013, 03:35 PM
  #123
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ended up using about 1/2” of dihedral under each wing tip. Just enough that it is noticeable and keep from having the straight wing look.
To be continued…
ID:	1845720   Click image for larger version
8178 is offline
Old 01-30-2013, 10:15 AM
  #124
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Installing the internal aileron parts; hinge points, end caps and linkage mount before adding the top sheeting on the left wing panel.
A small cut was made at the aileron ends so I can find the ends when the top sheeting is installed.
To be continued…
ID:	1846035   Click image for larger version
8178 is offline
Old 02-02-2013, 08:57 AM
  #125
8178
8178's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on the left wing panel. The top trailing edge, rib cap strips and center sheeting is on along with the 1/8” X 3/16” basswood strip on the trailing edge. The lower sheeting is not installed yet so I can add some sheer webs on the main spars.
Next, the wing tip block, sand down the basswood trailing edge, cut out and complete the aileron, install shear webs on the main spars, bottom center sheeting and make a 1/4” thick plywood center wing joiner that will fit between the upper and lower wing spar.
Sanding the basswood to an edge takes some effort but I think having a sharp hard edge is worth the extra work.
To be continued…
8178 is offline
Reply
Display Modes
