Kaos .60 vs DIrty Birdy .60
I know you guys are talking about .60 size, but I found this conversation interesting because I just started a short kit DB40 from David Oxilla. You can see I've barely started with the side panels, but you have to start somewhere. I'm wanting to join the CPA and fly it with retracts and a pipe, but I don't know how close events will get to me so I might need to travel some. Haven't decided on an engine yet, but will be going with E-flight gear and other recommended hardware from doxilla. Will Futaba TX hook up with spectrum RX?
Dave
Dave
Don't think you will get much closer than that !!
Dave..
Hey Dave, that's great to hear and a real motivator! I've been a member of the Birmingham R/C Club for about six months now and fly at the Morris field. I'm looking forward to getting the DB40 built, but I know squat about pattern so I have a lot to learn.
Dave
Dave
Hey Dave,
I'll be glad to help you any way I can ! I CD the last pattern contest @ the Morris field and even CD a couple of Club-40 Pylon races there. I'm not a Member but know quite a few of them. WE are going to have a Novice Only contest in the fall of the year at Alabaster and might be something you could get into. This contest is flown using the SPA novice maneuver's and is a very good way to see if you like pattern.
We will allow any airplane you have up to 95 4 stroke or a 65 2 stroke. We try to keep the airplanes down to the size that we normally fly in CPA or SPA !! If you have any questions send me a PM and I'll do my best to answer any questions you have..
Dave Phillips..
Dave Phillips..
