Blue Angel - Build
#52
PA
RE: Blue Angel - Build
Boy what a simple and great trick. It is these simple things shared that makes me feel, now why didn't I think of that. Thanks, the classics and tips like this is what keeps me looking.
#53
My Feedback: (17)
ORIGINAL: burgh_guy61
All the credit for the fuel tank mount goes to Tony Howard at Howard Engineering. They are without question the best engineered kits that I’ve ever built. It’s too bad they are not available anymore but the market for “Classic” kits is pretty limited.
#54
My Feedback: (19)
OH
ORIGINAL: 8178
One of the things I always liked about the old Rom-Air retracts is that they would stay retracted for transporting and aircraft storage. While I was ordering my new Spring Airs they suggested a simple solution to keep the Spring Airs retracted. I just made a small wire retainer with a ribbon attached to it so it would not get lost. Pretty slick!
To be continued…
To be continued…
Usually they leak out over a long time, but they stay up long enough for transport and such.
Bob
#57
My Feedback: (17)
The nose gear mount is glued to the back lower edge of the firewall with 30 min epoxy. I used a square to keep it aligned while the epoxy set. I like to build the firewall, nose gear mount and tank mount as a unit before it is installed in the fuselage so there is easy access for drilling holes and installing all the blind nuts, etc.
To be continued…
To be continued…
#58
TX
8178,
Does your steering arm extend out beyond the edge of the firewall, or is it just the angle of the pic? Just wondering how you were going to overcome that if it does extend out too far.
Tim
Tim
#59
My Feedback: (17)
The original Blue Angel used beam mounts and only had a thin firewall, so I’ve modified it by designing the firewall to hold the radial mount. The area from the bottom of the firewall to the front of the aircraft and the bottom of the nose is a balsa block. I’m not sure that the arm will need to go forward beyond the firewall line for steering movement but if so I’ll hollow out space for it in the balsa blocks. I’m flying a little blind because I’m building from plans that are designed to build a kit with pre cut wood and from my memory of my friend’s FK speeda.
#62
My Feedback: (17)
ORIGINAL: rainedav
8178, I can't quite make out the type of throttle linkage you're using. Is it a ball link? The work so far looks extremely neat!
#63
My Feedback: (17)
The Spring Air nose gear requires that the steering cable to be mounted so the control arm linkage is held at the center of the retract pivot point. My solution to this is a removable mount on the front of the cable sheath so it can be moved out of the way to install or remove the retract unit. If I make a removable clamp at the servo end the complete linkage can be removed. The mount bolts screw into blind nuts on the top of the retract gear mount. The steering cable control on the Blue Angel is tricky because of the low position of the retract steering arm and routing the cable over the top of the wing. I’ve cut dwells in the side of the F3 former in front of the wing for the steering cable and throttle cable.
To be continued…
To be continued…
#64
8178, since I've never installed a nose gear retract before, what exactly happens to the steering linkage when the gear is retracted? Does it disengage somehow or does the cable go slack as the wheel is raised? Or is it set up so the steering arm doesn't move laterally? in that case does the arm rotate on a shaft? Since I'll be using a nose retract in my UFO I'm really curious and equally confused. Thanks.
#65
My Feedback: (17)
On the Spring Air system the steering linkage on the retract steering arm just slides back and fourth on the arm shaft when rudder is used with the gear retracted. That’s why you need a mount for the front of the cable to hold it in the correct position.
#66
Awesomely simple and ingenius. I makes total sense now. Thank you. The more I think about it, the more I lean towards the Spring Airs (I still haven't bought mine yet).
I really like your method of building the whole engine/firewall/plumbing/retract unit first before even starting the fuse. It makes a world of sense, getting all that worked out ahead of time. Unfortunately, a lot of times when I build I just start glueing and then run into problems, glueing myself into a corner, so to speak! Please take it as a compliment that I've decide to let you resolve some of these construction decisions before I tackle my UFO fuse.
#70
My Feedback: (17)
Now that I have the wood from Dynamic Balsa, I moved ahead with the fuselage construction by transferring the shape of the fuselage side doublers on to 1/8” light plywood and cutting them out with my Dremel Moto-Shop jig saw.
As discussed before the fuselage has very complex shapes and I decided that the only way to assemble it would be some sort of fuselage jig to hold it in alignment. I used an old building board (plastic covered shelving) that I was about to throwaway as the jig base. I drew a center line down the board using a straight edge and a lead pencil. I then transferred the former positions from the plans along the center line. Using a square I projected the lines so they were about 4” out from either side of the center line making sure they were precisely square with the center line. I picked up some 3/4” X 1 1/2” smooth cut wood at the hardware store and then cut it into three 8” long pieces. Vertical center lines were scribed on the blocks. I cut three ¼” X ½” X 4” plywood pieces for clamps and drilled the ends for wood screws so they could be screwed to the 3/4” X 1 1/2” blocks to make the clamp. They are set down a little from the top of the 3/4” X 1 1/2” for clearance with the fuselage sides. The next task was to epoxy the 3/4” X 1 1/2”s to the base after checking that the vertical surface was absolutely square with the base. The 3/4” X 1 1/2”s were glued down to the base and lined up with the center line and the former lines. The firewall 3/4” X 1 1/2” block was glued down with a 1 degree right thrust (the aircrafts right not the jig) as defined on the plans.
So far the jig looks like it might work out pretty well. To test the alignment you can view the former alignment marks through the fuel tank hole in the firewall and see all the way back to the former behind the wing and on to the very back of the tail when the balsa sides are ready to be pulled together in the tail.
Some images of the jig while I was testing the aliment using the fuselage side doublers. I’ll glue the balsa fuselage sides to the doublers before gluing the assembly together.
To be continued…
To be continued…
#73
My Feedback: (17)
ORIGINAL: impactiq
This build does the heart (and mind) good 8178! I can not wait to see this bird done!
#75
My Feedback: (17)
The 3/16” balsa sides on the Blue Angel have a front and back section that join mid wing. I used my usual method of tracing the parts onto blue lined translucent drafting paper. Not sure if they still make it because my stock is from my RC aircraft designing days back in the 70s. The paper has a grid of 1/10”squares and a darker line every square inch. The grid helps line up the paper to one of the long straight lines like along the top part of the side pieces. I rubber glued two 36’X3”X3/16” side pieces together for the back fuselage sides and then rubber glued the tracing on top of the pieces. I made sure that I had two pieces that had straight edges on one side for the top part of the side. I had to do a little sanding and checking with a straight edge to make them perfect. Next, I doubled checked that the Dremel Moto-Shop jig saw blade was square with its table top and then cut them out. I did the same for the front side pieces. Then I taped a straight edge down the center of my new building board to use for alignment of the top of the side pieces. The butt joint between the front and back part took a little sanding to mate the parts with 0 gaps. I put the parts on both sides of the straight edge, glued the butt joint and then taped them down to the board.
After the glue dried I glued on the doublers and weighted them down for the glue to dry.
From looking a at the side pieces you can see why I needed the jig! So far everything lines up perfectly
The images below show the drafting paper I use, the completed sides and test fitting them in the jig. The plan shows some kind of MK threaded block bolted to the fuselage doublers for the wing bolts. I’ve cut slots in the light ply sides for ¼” plywood blocks to be drilled and threaded for the wing bolts.
To be continued…
To be continued…
