KAOS AND RELATED PLANES AND INFO
#901
The cowling on that plane is the same as the Warlord 40 and Warlord 25. It is what the cowling looked on the very first Kaos before it became the Super Kaos.
#902
Starting a Kaos kit.
I loved my Bridi Super Kaos 40 that I flew for years but lost it a couple a years ago when the ailerons jammed. I picked up a Tower Kaos 40 kit on Ebay for a reasonable price shortly after that and built the tail feathers but got distracted and got into other projects. All this talk about the Kaos has made me get the kit out again and I am just starting on the wing. Some minor changes but still that double tapered wing. The Tower Hobbies kit is out of production now.
#903
#904
Saw a few posts about using the 55AX. It is a strong engine. I was given an Atlas (66" wing, 7.6 lbs) and powered with a 55AX, stock muffler, MAS Scimitar 11x7 prop, 15% fuel. I could knife-edge the whole runway (600'), go vertical for 200' before it slowed. I flew in wind ups to 20 mph with it.
It was great flying. I lost the Atlas in bad wind though on landing.
Using a MACS or JETT muffler will help the performance some more with the 55AX.
A flying buddy had a 46AX in his Tower KAOS 40 and changed it to the 55AX after seeing my Atlas fly. He's much happier.
#905
I have bought 4 or 5 from them in the past 8 years.
I usually power it with the OS 55AX with a Jett muffler. Turns the 10x9 APC fast enough to go 100-105 mph. Have also used the 55 with a 11x8 prop and tuned pipe.
My favorite plane to fly!!!
Just got me a 60 sized one from Tower, currently modifying it to a taildragger with retracts. Power is an OS 75AX with tuned pipe.
#906
I got the Tower 60 ARF also. Flies very good. Mine has an HB .61PDP with OPS pipe. Great vertical. Mine was modified in various ways to reduce weight by about 6-7 ounces, the biggest one being replacing the motor mount with a much lighter mount. The one that's included weights a ton. Vertical with the 75AX should be impressive
#908
Driving those skinny ailerons at their middle is a great idea.
Considering the speed potential, strip ailerons driven with vintage linkages with a single wimpy servo of the day, you've got to wonder how many buzzed and blew up.
#910
For those building from scratch or a kit any classic with strip ailerons, let me recommend doping carbon veil to the strip ailerons. Even soft wood becomes very sporty. Then you can cover your finish as you please over the veil.
#911
I concur. But in this instance, I did not have to modify a thing; the Tower Kaos came to be set up this way. Also the ailerons are made of firm balsa and are about 1/8" at the triling edge. In my experience, Kaos' are a bit slower rolling than other pattern planes given the same aileron throws. Probably because of the thick wing. I just program a bit more throw % than usual.
#912
Here is a vid a fellow club member shot of me tearing up the sky with my Killer Kaos. It has retracts and a NovaRossi R60F with the NR tuned muffler. It's built from a BlueJay kit. The first half of the vid is me practicing the SPA Novice routine. The second half is gear up and wide open. It's the best flying plane I've ever had.
I use 2 aileron servos and she rolls faster than I need. During the second half I do a couple rolls on high rate at high speed and you can see what I mean.
https://www.youtube.com/watch?v=gSlBbRUxA3E
#913
NY
Nice plane and flying!
I just picked up a Bridi Killer Kaos kit yesterday at a local auction. I was lucky to get it!
#914
CA
#915
#917
#919
Thanks for kind works guys. Yeah the KK is a better plane than I am a pilot. I also have the Tower 40 Kaos arf. It is really fun plane but the bigger 60 Killer tracks and does pattern a lot better. It tracks so good it's almost like it doesn't want to turn. ;-P The Bluejay kits have the best balsa I've ever seen in a kit. If I built another KK I bet I could build it under 6lbs with fixed gear. Mine came it around 6.5 lbs. That NovaRossi sure pulls it good.
Happy flying!
Happy flying!
#920
My Feedback: (7)
Tower still sells it as an ARF.
#921
My tower kaos 60 was balanced at the rearmost point as per the instructions when the clunk in the tank separated from the tank spilling 80% of fuel rearward and in turn loosenind on of the 6v batteries which then flew over the servos to the back under the pushrods.... the plane didnt even flinch. Flew it like 2 mire minutes until engine sputtering made me land it. Until then I didnt know anything had happened. So in reality CG was way further back than suggested for those 2 mintes. If anything it flew better. The thick airfoil is very forgivivig. I now have the CG set permanently about 3/8 further back of the suggested rearward limit and rolls, spins and snaps really came into their own, but no tail heavy squirelliness. Go ahead and move it back, just do it a bit at a time
#924
I have the 40 arf. I too thought the suggested CG was too far forward. I looked up the original Kaos plans and they show it on or toward the rear of the spar. That is where I balanced mine. Took 2 ounces in the tail with the receiver battery behind the servos under the pushrods. It still seems a tad nose heavy. It will inside snap and spin but won't do an outside snap or spin unless it's slowed. My 60 Killer Kaos has the cg a tad behind the spar. It will snap inside or outside at full speed.
