Aurora 60 Build Thread - Electric Power
#201
RE: Aurora 60 Build Thread - Electric Power
ORIGINAL: mmattockx
Jeff,
Jump over to the regular pattern forum and look up the Black Magic VF3 build thread. Find Handglider in that thread and PM him about paint masks. He is doing some amazing finishing work with masks in that thread and is quite willing to do custom work for others. Tell Dean I sent you!
Mark
ORIGINAL: Bootalini
I'm going to make a few phone calls tomorrow and find out about having masks made commercially by computer.
Jeff
Jeff
Mark
david
#202
ON, CANADA
Just about there. Using the pre-cut masks obviously saves a lot of time...and ultimately yields better results. Not sure what type of vinyl the rest of you use for masks but I had to reduce the tackiness of the vinyl before I applied the mask.
Anyhow, I'll have the aircraft ready for clear coat here shortly. The rest of today will be spent touching up a few small areas, the worst of which is on the cowling where I used pinstriping to mask.
Jeff
Jeff
#203
ORIGINAL: dhal22
i looked through that entire thread and didn't see a lot of masking info. i see the results but not a lot of technique. but there are several (long) build threads there, perhaps i looked at the wrong one.
david
david
Dean doesn't have much on the technique in there, just the final results. He will custom cut masks for just about anything if you want them.
Mark
#204
ON, CANADA
Whew!...I'm seeing light at the end of the tunnel. All touch-ups are done and she's ready for clear. I'll likely take Tues or Wed off from work to finish the job.
Jeff
Jeff
#206
I second that. I'm positive I would be too scared to fly her. very well done.[sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif][sm=thumbs_up.gif]
david
david
#207
ORIGINAL: Bootalini
Jeff
Jeff
And wow, just wow at the finished product. Simply gorgeous, Jeff.
Mark
#208
ON, CANADA
I guess that does sound kinda funny. Gotta do what I gotta do though. I need to get this thing finished....I mean it's been how long since I started this thread?
Thanks for the kind words!!
Jeff
Jeff
ORIGINAL: mmattockx
Now there is a man who has his priorities straight.
Mark
ORIGINAL: Bootalini
Jeff
Jeff
Mark
#211
ON, CANADA
Chad, she'd be a blast to fly although don't expect it to knife-edge like your Twister. WRT Pete, seeing as how he's now firmly entrenched into the geeky F3P scene, he's no longer allowed to touch my pattern airplanes...
Most of the clearcoat has been applied and I'm almost done wet sanding and buffing. Holy cow..that's a lot of work! I wet sanded everything with 1500, then 2000, and followed with the scratch/swirl remover, and finally the polishing compound. Not as shiny as the original clear but that's the way I like it. I prefer a slightly duller and deeper shine as opposed to the ultra glossy finish you get when the clear dries.
Anyhow, let's get to some of the more useful data now that the finish has been applied:
As a refresher, the initial weights before applying the glass cloth:
-Fuse (minus belly pan, motor, and nosegear) = 562 grams
-Single wing panel including aileron (no gear or servo) = 205 grams
-Stab half, including elevator = 72 grams
Weights with the cloth and many Poly coats applied and sanded...i.e. the aircraft is ready for paint:
-the fuse weighed an additional 127 grams (689 grams)
-each wing panel (w/ail) weighed an additional 48 grams (253 grams)
-each stab (w/elev) weighed an additional 16 grams (88 grams)
Final weight with the complete finish applied
-fuse weighs 740
-each wing panel (w/ail) weighs 290 grams
-each stab half (w/elev) weighs 100 grams
Therefore the overall weight gain from this prep/finish method is approx 404 grams, or .89 lbs. I'm curious how that compares to other methods...anyone??
I'll post more pics in the next few weeks.
Jeff
-fuse weighs 740
Jeff
#212
ON, CANADA
Howdy folks. Just a quick note to let ya'll know that I finished the airplane over the holiday. What an insane amount of work sanding then buffing the clear back up but I'm satisfied with the results. I'll post more photos after I get the gear installed and the airplane back together.
Jeff
Jeff
#214
.89 lb gain, what's that about 14 or so ounces? monocote would be 4-5 oz? or more. i'll take the 8-10 oz gain everytime if my builds end up looking like that.
#216
ON, CANADA
Nope, it has not flown yet. The weather here in Ottawa is just starting to warm up and the primo flying weather is rapidly approaching. The limiting factor right now is that I've not yet purchased the lipos. 8s or 9s packs are pricey!! []
I'll be sure to capture the maiden flight on video.
Jeff
Jeff
#217
QC, CANADA
Jeff,
I've never used inexpensive lipo's but am starting to really be tempted, especially at these cell counts. I"m not sure if this is allowed but you might be interested in these:
http://hobbycity.com/hobbycity/store...idProduct=7656
http://hobbycity.com/hobbycity/store...idProduct=7657
Hard to beat the price!
David.
David.
#220
The saying goes you pay for quality...
I've been there with the cheaper cells, they just aren't up to it in my opinion.
#221
FL
Sometimes you just pay for a name, too. As in rebadged packs from Chinese sources who sell direct, and to resellers/rebadgers.
Rick
Rick
#222
I am looking for some time the plane of this model, I am very interested in it. Would you please send me a copy of your plane? Of course I pay the postage.
[email protected]
Sorry. My english lenguage is not very googd.
Thank you very much
[email protected]
Thank you very much
#224
Is it still not flying weather yet in Ottawa? I (and I'msure I'm not alone) eagerly await reports of the Flight Of The Electric Aurora...
G.
G.
