BPA prop choice for YS 61 R
RE: BPA prop choice for YS 61 R
I used to run a 13x10 on a ys 61ar but for speed maybe a 12x10 or 12x7 if you have ground clearance. The plane was a Robbe Saphire that weighted a ton but flew very well. I ran the engine on home brew 20/20 with a Hatori pipe on the long side.
The LS's like to rev low so start with something in the 12" range with a bit of a bite. Like I said before a 12x10 might be a good option. I don't think you will have ground clearance with a 13". You might also want to try an 11.5x10.5.
Handglider,
I have a YS-61 LS and I had it on a TFrackoviac "Challenge" and I ran an APC 12 x 9 turned approximately 12.5 K on 15% Omega fuel. Great combo and extremely quite. Getting any aircraft/Prop/Fuel/Pipe set up takes some "Tinkering" or it has been my experience, its the WHOLE package so YOU can't just grab anothers recommendation and run.
I have 2 Asano props and 3 DK props which are NOW Classic's!
Tony
Boling,TX
Tony
Boling,TX
