Hanno MKI and MKII
Old 09-23-2015, 09:44 PM
  #101
speed-panzer
speed-panzer's Avatar
All the best for coming weekend, and enjoy the EU1 flights, of course!
By the way, may I ask, what was the approximate price tag for the YS 61R Classic for you guys over there? Someone here may sell his NIB one, asking about 380$.
Dominik
Old 09-24-2015, 05:23 AM
  #102
computermonkey
My Feedback: (90)
Originally Posted by speed-panzer
By the way, may I ask, what was the approximate price tag for the YS 61R Classic for you guys over there? Someone here may sell his NIB one, asking about 380$.Dominik
In the US They range at the start of the sale 350 US dollars to 300.
IS the 380 US dollars or Eruo?
Old 09-24-2015, 05:36 AM
  #103
speed-panzer
Sounds ok...
It is 380US$, around 340€
Thanks for info!
Old 09-24-2015, 06:07 AM
  #104
computermonkey
My Feedback: (90)
your welcome
Old 09-25-2015, 04:28 AM
  #105
time907356
FWIW - I paid $299US, and there was a sticker on the box for $319US.
Old 09-27-2015, 03:11 AM
  #106
jayjayneri
Guys, I have a great running Hanno Special that was damaged in a crash a few years ago due to Rx battery failure. The front of the carb got chipped which is just cosmetic. But there are a couple of small cracks in the crankcase at the mouth of the carb mount area. I did run the engine on the bench a couple of years ago and it run fine. I know I will have to repair or replace the crankcase before flying the engine.
Does anyone know if a regular 61 RF-P crankcase will fit? Or anyone selling a replacement Hanno crankcase? I have tried repairing similar damage on an OS 46 VF engine using Devcon high temp epoxy in the past and it did seem to work so I can probably do the same with this engine.
Or would there be any interest in this engine if I were to let it go? I am not really looking to sell this engine but I would be very interested in a trade with a NIB Hanno pipe and good continent Hanno box and manual. I was able to recently obtain a new in box Hanno Special but the box is in bad shape. And, no, the new Hanno is not for sale.
Thanks guys....
Old 09-27-2015, 03:13 AM
  #107
computermonkey
My Feedback: (90)
Hello, Hanno and RF-P use the same case.
Old 09-27-2015, 06:19 AM
  #108
jayjayneri
Thanks. I will try to get a new RF-P crankcase.
Old 09-27-2015, 07:06 AM
  #109
jayjayneri
I have #3783 which is used and slightly damaged and #6670 which is brand new. I got them from a friend and both came with only one tattered box. I am looking for a like new box with manual and accessories if case anyone has one for sale. I am also looking for a new in box Hanno pipe if anyone has a spare.
Am I right in assuming that my #6670 is a Hanno II? It is the ABC version, by the way.
Old 09-27-2015, 09:41 AM
  #110
doxilia
doxilia's Avatar
I'm not certain of this but I believe the Hanno case is a modified RF case. The exhaust port has some additional machine work and I suspect that the intake and boost ports are also slightly different than the standard RF (or RF-P simply a pumped version of the RF).
David
Old 09-27-2015, 10:12 AM
  #111
computermonkey
My Feedback: (90)
David correct the Hanno had the exhaust milled out at the top corners, other than that the case is the same cylinder bearing size etc.
I would believe jayjayneri would have better luck finding a RF-P case before a Hanno case. If he wanted to he could file the corner to match his cylinder.
Old 09-27-2015, 11:31 AM
  #112
doxilia
doxilia's Avatar
Ralph,
did you compare the Hanno & RF crankshafts as well? Again, not certain, but it's possible that the rear bearing race of the Hanno might be a little larger if the crankshaft was beefed up in that area. If the outer race is the same diameter, it's not a problem but the rear bearing for the RF might not work on the Hanno shaft - just speculating. I'm also not sure that the porting on the RF case is identical to the RF but that might not present a huge issue other than perhaps a little loss in power if any.
Yup, no doubt about that. Worse case scenario, if the RF case can be made to work, the engine will perform like a hybrid of sorts.
David
Old 09-27-2015, 01:08 PM
  #113
jayjayneri
Yes, I am aware that I would need to port the exhaust a bit and the rear bearing may need to been changed to a slightly smaller one but the RF-P case can be made to work. I am also trying to track down an original Hanno crankcase from a damaged engine but if it does not work out, then the RF-P case would have to do. Thanks for the info guys.....
Old 09-28-2015, 02:55 AM
  #114
jayjayneri
Just curious, any idea what a brand new Hanno II is worth now? Thanks
Old 09-28-2015, 03:11 AM
  #115
time907356
Old 09-29-2015, 03:20 AM
  #116
dhal22
I wished I could list one of mine right underneath his for 75% of that. Might just do that.
Old 09-29-2015, 03:26 AM
  #117
time907356
Old 10-21-2015, 06:44 AM
  #118
jayjayneri
Just an update. I got a new OS61 RF crankcase and swapped it out with my damaged Hanno crankcase. Everything fit perfectly. I also broke out the Drexel and milled the tops of both sides of the exhaust port to match the original Hanno crankcase. Just waiting for my Modeltech Calypso to arrive so I can run this engine again. Since shifting to electric some years back, I miss the smell of nitro. LOL
Old 10-21-2015, 07:55 AM
  #119
time907356
Did everyone see the Hanno go for $235 this weekend, with pipe and header?? That should be a shot over the bow...
Old 10-21-2015, 11:09 AM
  #120
flywilly
My Feedback: (121)
The listing was a little misleading. The engine was not new and did not include pipe or header. It was a very low time engine based on the head color.
Old 10-21-2015, 11:28 AM
  #121
time907356
It said pipe and header, didn't it? (I erased it already) ....So, VERY misleading then! But still, economical.
Old 10-13-2021, 01:20 AM
  #122
babbott78
Just adding my NIB Hanno Mk1 to the list.
Serial #4491
Old 10-13-2021, 06:07 AM
  #123
flywilly
My Feedback: (121)
Very nice! Are you planning to run it? If so, what airplane?
You might want to consider purchasing one of Brian Gardner’s true ABC replacement piston/sleeve sets if you are going to run the engine. They last much longer than the stock parts. Look in the classic pattern forum on RCGroups for more information.
-Will
Old 10-13-2021, 07:31 AM
  #124
babbott78
-Will
Hi Will,
I spoke with you re a second set I have a second Hanno that’s a “runner” that I’ll be running and have a Brian Gardner set ready for that engine (with 2 more sets on the way). I have the hatori header for it as well. I have two NIB Bolly Carbon EQ63 tunes pipes I plan to run too.
From what I can tell, the “runner” Hanno looks like it’s had a normal RF crankcase, and potentially a normal RF crankshaft. The rest of the engine appears to be Hanno. I’ve dremeled
the relief ports onto the exhaust exit to match the liner, but I can see the rear bearing face, so assume the crankshaft must be a normal RF crankshaft. Liner is definitely Hanno, as is the pump, Carby, head. It had no
serial number in it either. Has great compression.
The plane it’s going into is the Bolly Lotus 5, by Peter Goldsmith (90’s F3A plane). I have next to it Flying already, the Slingshot (I have a YS115S in that plane).
looking forward to running the Hanno as I still remember them as a kid when I was at the pattern contests.
Old 10-13-2021, 08:35 PM
  #125
babbott78
Have also managed to secure a Hanno Mk2 crankcase, conrod, and crankshaft (all NIB) so I can use these on the running Hanno I have
