Benefits of 91 4S over 61 2S in SPA model
YT
RE: Benefits of 91 4S over 61 2S in SPA model
What about the Saito 91 FS?? It's cheaper than the OS and lighter. It also eats 30% nitro heli fuel with no problems. I heard thats a bad idea with the Magnum FS. Why is this motor never mentioned??
I see it's more powerful and lighter than the OS or Magnum according to the listed specs. Looks nice.
I saw your post on another thread about the engine and I see no reason not to use the Saito.
Does anyone else have info on the Saito 91 FS out there?
I saw the lowest price on a Magnum is $169 at Abell Hobbies.
Chris...
Chris...
ORIGINAL: stuntflyr
Chris...
Chris...
The bottom line between the Saito and OS 4-strokes as I understand it, (and to a certain extent have experienced it), is that the Saito is lighter but not as powerful. According to those I trust the OS is tops when it comes to reliability and consistant running. There are many SPA pilots who hardly if ever touch their needle valves once they're properly set. I've also heard OS has less mechanical problems over the long term.
If the muffler is bored out slightly, (plus maybe a couple other legal mods to the engine), an OS .91 FS will outpower a Saito 100, while being much better on fuel economy. Having both the Saito 100 and OS .91, I can tell you there is very little difference in performance,and a big difference in fuel usage.
These are the general feelings around SPA regaring these two engines......almost everyone flys O.S. Everyone is trying to coax every last RPM out of their mill for best vertical performance. They try to use the right fuel, the right prop etc to achieve that goal. With that in mind, I don't know of anyone who chooses the Saito over te O.S., in spite of the Saito being lighter.
Duane
4 stroke hands down beat a 2 stroke glow engine any day. I will not fly a 2 stroke on any of my planes without a pipe, so it is 4 stroke for SPA period....[8D]
My Feedback: (23)
ID
I've run Saito and OS 91's in SPA airplanes. Kaos and DR respectively. What kingaltair says couldn't be more true. If I wanted to save money I'd try a Magnum before going back to Saito. My Saito was a great running engine, but there is no way its being lighter made up for its lack of power. I won't be surprised if a OS 75 could out pull a Saito 91.
#31
My Feedback: (14)
ORIGINAL: Sport_Pilot
Mickey Walker has been using a TT Pro .61. I would consider that as well as the Tower, Fox, K&B, and Supertigre .61.
On the other side, if money doesn't matter. Webra, HP, and Jett have good motors.
ORIGINAL: KLXMASTER14
In the same context, is the difference in performance between a $100.00 Magnum .61 2S and a $180.00 O.S. 61FX worth the payout for the O.S? Your opinions please. This would be using them with mufflers per SPA usage, not piped.
-Robert
ORIGINAL: stuntflyr
Tell me this about these two engines;
Is the difference in performance between a free Magnum 91 4S and a 300 dollar OS 91 4S worth the payout for the OS?
Chris...
Chris...
-Robert
Let's not forget the Rossi and Novarossi engines. With an adapter plate and a Jett or PSP performance muffler, the Rossi engine aren't that much more expensive than OS.
Ed Cregger
#32
My Feedback: (121)
The AXE Rossi can be purchased with a 'tuned' muffler; it appears to be marketed for the SPA folks. Occasionally, Sahak (the AXE Rossi distributor here in the USA) will put one on ebay. I'd guess there's not a lot of weight difference between the Rossi and the OS 4-stroke.
#33
My Feedback: (15)
I have been on an OS61 SF and OS61 FSR buying binge, and now have several, NIB. You can get these powerhouse's in the $200.00 and sometime less range, on E-Bay. They are coming out of the woodwork. Instead of spending $300.00+ for something, you can get these great 2 strokers. I did find a Rossi that Sahak put on E-Bay for a great price, and it is in Phoenix # 1.
Crank
Crank
#35
My Feedback: (15)
Hey Astro - Yes, a Mac's, and you are in luck. I save everything. Pictures here of the part numbers. I ordered mine from Mac's Products, direct. I think I spoke with David. He called me back twice, after I sent him some mail about the adapter and muffler for this Rossi 60. He wanted to make sure that they provided the correct piece. This adapter is made special for the specified muffler, as one of the muffler mounting holes is open on one end, it does not impede mounting. Maybe this adapter will fit other muffler's, etc..
I think it took about 2 weeks to get the muffler and adapter,they may have made it special at that time. It is a stock item, so the part probably was not in stock. Great service and attitude at Mac's. I believe you can machine some stock out of the outlet of the muffler and the adapter. Whether this would make some weakness there, I don't think so. I am not a machinist.
I purchased this Rossi 60 about 8 months ago, the latest production at that time. Nice piece, and my first experience with Rossi.
Crank
Crank
#36
My Feedback: (14)
ORIGINAL: turboomni
It is a regional thing, I suspect.
I'm selling off a lot of my modeling stuff. I simply have more than I can ever use, so why tie up the capital and space? With that in mind, I sold my OS FS-91 Surpass II Pump just the other day. I'll use my Saito or Magnum .91 in its place. I have a couple Cline Regulators still NIP, so I'll use that if it turns out that I really need to do so. I doubt that I will.
The Saito .91 has a great reputation for being the strongest of the three we are talking about, while also being the lightest. Saitos are just as tough as OS four-stroke engines, so there is no downside to using the Saito in place of the OS.
Just my opinion.
Ed Cregger
