Don Lowe Phoenix 8
Old 12-10-2009, 08:50 PM
  #101
RonMcCormick
RonMcCormick's Avatar
Default RE: Don Lowe Phoenix 8
Yes Aztec Air, talked with him a few days ago and it will be quite a while before hes back in production.
Old 12-10-2009, 10:29 PM
  #102
spotter
I have a Phoenix 8 fuse, says 1976, belly pan, firewall, wing blocks. Plans, showing the root and tip airfoils, also elevator airfoil. One foam wing severely degraded by time, but can be measured for plan view, span, and airfoil. I would trade it for a Top Flight Bonanza kit, or maybe something else interesting.
Foam wings can be ordered from: http://www.eurekaaircraft.com/foamwi...amwingmain.htm
Old 12-10-2009, 10:34 PM
  #103
crankpin
My Feedback: (15)
I would guess it is an epoxy fuselage. What about some dough ?
Crank
Old 12-10-2009, 10:53 PM
  #104
kingdom802
I have a set of Phoenix 8 new in the box foam wing cores for a good price if anyone is interested.
Old 12-11-2009, 09:10 AM
  #105
spotter
Yes, it's epoxy, identical to your photos. Not interested in money, just looking for hard to find items. I've been wanting to buy and build a TF Bonanza for two years. I'm tired of ARFs, I haven't built anything since 2003. Something scale, trike, 60-90. I gave up looking for a TF P-39. That "auction site" is a pain to search, so many toy electrics.
Old 12-11-2009, 10:08 AM
  #106
crankpin
My Feedback: (15)
See what I can find.
Crank
Old 12-14-2009, 12:04 AM
  #107
evaristus
Oh boy just found this thread, I remember the review in Model Airplane News, September 1979 , about this plane and myself daydreaming about flying it (er.., afford it I was 15 then) , as soon as I see one I´ll get it and ...
Old 03-13-2010, 12:44 PM
  #108
zdog
Is it possible to purchase a phoenix 8 kit ?  what or who is pac ? been away for awhile and don't recognize any of the current nomenclature lol
thanks my e- mail address is j_patrick@bellsouth .net
Old 03-14-2010, 07:46 AM
  #109
Deadstik
My Feedback: (8)
Deadstik's Avatar
zdog,
George Truett at Aztec Air has the molds for the Phoenix 8 but is presently not in the country. [link]http://www.aztecair.net/Phoenix_8.htm[/link] I'm sure George checks this forum so perhaps he will post when he'll be back in the US and produce kits.
Dan Hines
Carolina Custom Aircraft
Old 09-07-2014, 12:57 PM
  #110
RonMcCormick
I have a Deluxe P8 kit for sale. This has factory pre sheeted wings stab and rudder. tips shaped and sanded excellent and rare kit.
ID:	2030442   Click image for larger version
ID:	2030443   Click image for larger version
ID:	2030444   Click image for larger version
ID:	2030445   Click image for larger version
ID:	2030446   Click image for larger version
ID:	2030447   Click image for larger version
ID:	2030448   Click image for larger version
ID:	2030450   Click image for larger version
ID:	2030451   Click image for larger version
ID:	2030452   Click image for larger version
Old 09-07-2014, 10:53 PM
  #111
samdimaio
My Feedback: (106)
interested in your p8 - please email your phone number or call: [email protected], 610-436-5552
Old 09-11-2014, 07:03 AM
  #112
jon bruml
my don lowe p-8 . it took me 3 years but I got it done.
Name:	i phonr 025.JPG
Old 09-11-2014, 08:02 AM
  #113
crankpin
My Feedback: (15)
nice ! Mind if I copy that paint scheme.
Crank
Old 09-11-2014, 08:14 AM
  #114
Jim Oliver
Jon,
Looks like you ran the pipe above the wing, something I have been considering for my P7......how did that work out?
Jim
Old 09-11-2014, 08:48 AM
  #115
jon bruml
Truth is I have not flown it much so I cant tell you if the side mounted pipe effected flight characteristics
I can say that both Chip Hyde and Richard Verano recommended this set up and I trust those guys
Old 09-13-2014, 12:56 PM
  #116
RonMcCormick
Default What pipe is it?
Does anyone recognize this pipe? I have a straight and bent version for .60 ci glow. I think it's an ED been a few years (1978) and inside the outlet what are the threads for?
BTW Jon, sweet Phoenix!
ID:	2031620   Click image for larger version
Old 09-22-2014, 07:33 AM
  #117
Malcolm H
Malcolm H's Avatar
Yes Ron,
Ron,
They are indeed ED Quiet Pipes. They all had those threads on the inside of the stinger (extended outlet onto which the rear silencing can fitted). I was never sure why the inside was threaded as the thread is only needed on the outside of the stinger to hold the can retaining nut. These pipes were designed by Kevin Lindsay a U Control speed flyer who realised that a double cone tuned pipe would be too peaky for R/C use and so came up with the smooth transition from one cone to the other. There may have been some good engineering reason why the inside was threaded but I suspect it was something to do with the manufacturing process.
Malcolm
Old 09-22-2014, 03:06 PM
  #118
RonMcCormick
Ok Malcolm, thanks a lot. I appreciate the info. I think I will play with it on my Phoenix 7.
Old 09-22-2014, 07:24 PM
  #119
TonyF
My Feedback: (92)
Dave Brown made the ED pipes popular in the USA and World Engines imported them. I also used them while I was with World and the bent version was a good fit on a Tiporare or Curare. We also used the bent pipe on the Phoenix's. It is kind of a fragile pipe, though it was quieter then some made out of better material. Inside the pipe is a weld where the stinger that has the threads comes out of the convergent cone. That weld would often fail. Also, the muffler can that is held on with the exhaust pipe tends to come loose. If you note, in the muffler can there is that ridge just rear of where the can meets the convergent cone. That was to allow the pipe to flex when it heated up. But if it ever gets loose, the weld fails pretty quickly. Some of us started to silicone the can on to the pipe or even JB Weld it. We also started to drill and tap the exhaust piece through the stinger to keep it from backing out. But eventually they would fail. Macs Products for a while made a bent version of their muffled tune pipe to replace the ED one and it worked the same but since it was made of a harder aluminum it would ring. You could hear it more at partial throttle settings. Wish I could get a Macs Bent pipe!
Old 09-26-2014, 09:33 AM
  #120
BERUSTY
I may have an extra ED and Macs bent 10cc pipe. I will look over the weekend.
Rusty
