Mach 1 Laser Kit Build
Reply
Old 10-25-2012, 05:26 PM
  #176
Pattern One
Pattern One's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mach 1 Laser Kit Build
Hi Jon,
The Sequel thread will be updated after I get some more done on the Mach 1.
Leo
Pattern One is offline
Old 10-29-2012, 12:54 PM
  #177
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I completed the nose gear cover so I can get to things if I need to. There is enough room for a battery up front if needed for balance. Tail feathers and wing mounting are next. Then I can determiine the nose gear length and cut the nose gear block out. Pictures of the progress.
ID:	1816026   Click image for larger version
Old 10-29-2012, 05:48 PM
  #178
R_G
R_G's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I really like that removable nose gear cover! Great Idea!
RG
R_G is online now
Old 10-30-2012, 07:55 AM
  #179
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RG,
Thank you. After all the hard work we do on these we need to have a way to access things when we have a malfunction.
Leo
Old 11-03-2012, 12:59 PM
  #180
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The stab and vertical fin are mounted. I placed a bubble level across the engine mounting beams and another on the stab saddle to check alignment before I glued everything. Everything was right on. A little finish work left on the fin then it's on to wing mounting and I may add flaps like those on the Curare to slow the Mach 1 down a bit for landing. What do you guys think about adding flaps to the Mach 1?
Leo
Old 11-05-2012, 04:06 PM
  #181
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I added some filler pieces on the stab and fin today. Some final shaping and micro balloons should give it a nice finished look, but that is for the next update.
ID:	1817946   Click image for larger version
Old 11-14-2012, 06:01 AM
  #182
E Strader
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Crankpin, Is that a picture of a Mach One with a side mounted engine? I plan to order a Laser Tech Mach One and want to side mount the engine because they just look so much better and it tends to keep the plane cleaner of oil during flight.
Eric
E Strader is offline
Old 01-13-2013, 12:04 PM
  #183
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
It's been awhile since my last update so here it is. The wing, stab, fin and control surfaces have all been glassed and sanded. Fillets have been added to the fuse and shaped. I decided to do an engine change. Instead of the Webra 70 Speed I have switched to an OS 75AX. It was a bolt in. Finding a combination of prop nuts to work with the 2.25" standard Tr-Turn spinner was a challenge. I finally found the correct combination to make it work. My original plan was to use a Tru-Turn 2.25" FAI spinner, but due to the length of the OS 75AX crankshaft that was not possible.
The nose gear length needs to be established and the retract access cut in the removeable bottom block. A final sanding of the fuse and it will be ready to be glassed. I hope to have another update later this month. My goal is to have this ready for primer and paint when the weather presents an opportunity this spring. Not sure of the paint job yet. Klasskote for sure.
Leo
ID:	1839960   Click image for larger version
ID:	1839961   Click image for larger version
Old 01-13-2013, 12:58 PM
  #184
PatternPilot
PatternPilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks fast sitting there
PatternPilot is offline
Old 06-09-2013, 01:12 PM
  #185
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shot the Klasskote base color Yellow today. Some Red and Blue Klasskote trim and it will be ready for final assembly.
Leo
Klasskotemo
NovaRossi Engines
B&D Retracts
ID:	1890282   Click image for larger version
Old 06-09-2013, 04:16 PM
  #186
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Leo,
The yellow on your Mach 1 looks AWESOME.................! ! ! ! ! Are you going to put one of your new purple headed Novarossi monsters in it?
Take care,
David
hrrcflyer is offline
Old 06-09-2013, 05:04 PM
  #187
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David,
OS 75 AX for the Mach 1.
Leo
Old 09-05-2013, 10:42 AM
  #188
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mach 1 Laser Kit Build
It's been too long since my last update. The Red and Blue trim colors have been added. The fuse and control surfaces have been clear coated. I will clear coat the wing on Saturday. A NovaRossi R91CR will be powering my Mach 1. It's a direct bolt in for the O/S 75 AX I had planned. After a trip to Columbus, GA/Fort Benning next week I will be ready to start the final assembly process. This is the first time I have attempted to upload images since the big change at RCU. Hopefully it will all work.
Leo
Klasskotemo
NovaRossi Engines & Parts
B&D Retracts
Old 09-05-2013, 10:53 AM
  #189
EscapeFlyer
EscapeFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow... Very nice!
Brian
EscapeFlyer is offline
Old 09-05-2013, 05:13 PM
  #190
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brian,
Thank you.
Leo
Old 09-06-2013, 05:36 AM
  #191
DrAlexander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
beautiful ship you are working on there.
DrAlexander is offline
Old 09-06-2013, 05:39 AM
  #192
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DrAlexander,
Thank you for the kind words.
Leo
Klasskotemo
B&D Retracts
Old 09-06-2013, 05:53 PM
  #193
Jim_Purcha
Jim_Purcha's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nIce, I noticed it in the background of your photos in RCG. I thought it was a compensator at first.
Jim
Jim_Purcha is offline
Old 09-06-2013, 06:20 PM
  #194
rv7driver
rv7driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leo, great job, have always liked that color combo!! can't wait to see pic's when finished! Pete
rv7driver is offline
Old 09-07-2013, 07:17 AM
  #195
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim,
I emailed Rhett Miller III a short time ago for some color pictures of his Compensator bottom wing detail and had no idea that he had one version that used a White base coat with the same trim scheme. The famous Yellow color picture is easy to find in the magazines, but I had no idea he had the White version since most of the pictures from back in the day were in Black & White. I did want to follow the Compensator color scheme on the Mach1. The Blue is a Federal Standard color.
Pete,
I liked the color combo too. I shot the clear coat on the wing this morning and it turned out very nice. A tip when shooting the Klasskote clear is to add a slightly greater amount of reducer than the 1:1:1. Just a little bit. The clear lays down real nice.
Leo
Klasskotemo
B&D Retracts
Old 09-08-2013, 01:56 PM
  #196
hrrcflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by EscapeFlyer View Post
Wow... Very nice!
Brian
Brian, how right you are. I only wish I could build a plane and have it turn out half that nice.....................
Take care,
David
Old 09-24-2013, 05:04 PM
  #197
Yak13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leo, let me know how the NR91 performs. I am currently flying a Matt Atlas with a piped NR75, 11.5x12.5 thin prop. Amazing performer!! But the 91 should be even better. I have a GPS on the Atlas and it breaks the 150 mph mark systematically.
Let me know please, I really enjoy fast pattern planes.
Ed
Yak13 is online now
Old 09-25-2013, 05:19 AM
  #198
Pattern One
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ed,
Will do. Once I finish the Mach 1 and get it going I will update this thread. I have a some other R/C related projects that I am involved in right now.
Leo
Klasskotemo
B&D Retracts
Old 09-28-2013, 03:21 PM
  #199
Yak13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Leo
I thought I had responded to your PM but cannot find it here on RCU. So here it goes:
I am using the Eagletree systems GPS and data logger. It is compact and practical, but the software is very limited. It will give you the information though.
I will send you another message with questions regarding the Novarossi engines.
Best to youi!!
Ed
Yak13 is online now
Old 09-28-2013, 03:32 PM
  #200
Yak13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the Novarossi engines. I have a C75F that needs a new rear bearing. My questions are:
1- Can you supply it? Price?
2- Is there ant special technique to remove the bearings? I have replaced bearings on several engines but these seem to be very tight. I don't want to damage the engine.
3- Would you recommend the ceramic bearing for this engine? Can you supply it? Price?
4- I also want to buy a 91 for my Matt Atlas which currently wears the 75 (with a 10mm carb). Do the 91s have the same mounting bolt pattern that the 75?
5- I see that the only difference between the 91F and the CR91 is the 10mm carb. Am I correct? I really like fast pattern airplanes and the Atlas with the 91 should be awesome, especially with CR.
Thanks!!
Ed
Yak13 is online now
Reply
Display Modes
