Scoop! Hangar 9 Phoenix 7...ARF!!!
#301
RE: Scoop! Hangar 9 Phoenix 7...ARF!!!
my ultrasport 60 has an OS .61 RF with an enclosed pipe in the canopy. It is eerily quiet. and the pipe has a silicone tube exiting the bottom of the fuse so no oil residue. it can be done.
#302
AL
A .91 4c on a standard muffler is louder than my .61 2c on the pipe. I can see that statement being true if the pipe is not a muffled pipe.
Gary
Gary
#303
ORIGINAL: TonyF
It's very easy to make a .61 on a pipe quiet. And still have excellent performance. We did it for many years before the 4-strokes came out.
Could You tell us the main steps involved You made for silence a .60-.61 with tuned pipe? I'm sure it could be helpful also today (Maybe start a new thread if You think it is to much off topic in this thread).
- I know the air intake on carburator could be silenced with a "muffler" type thing.
- You could "soft" mount the engine with rubber holders.
- Not tune the pipe (but why use a pipe then).
- Cut some of the propeller tips since they make noise and contributenot much to thrust anyway.
- Use a long stroke 2-strokeengine(usually) to use larger props that do not need to rev as much and therefore give less noise.
- Build in the pipe in fuselage and do some silencing on the pipe arrangement.
More?
/Bo
#304
Because you can pay once for a set of batteries and fly it year after year.
I don't think those flying pattern back then would have wanted them to be that quite, just less noisey.
#305
I wouldn't fly this plane with a 2-stroke on pipe, because I wouldn't be able to bring it up to my local field and fly it, like I can with a .81-.91 4-stroke.
#306
ORIGINAL: Sport_Pilot
That's not my experiance, a plane of that size will require much more than $50 in batteries. Although reviever batteries ast 5 years or more, the heavy load on electric motor batteries last about a year. Unless you don't fly that much or are satisfied with much shorter flights, and don't mind waiting for them to charge.
And yes, taking care of batteries (not storing charged, not over-discharging, not over-charging, not over-heating, etc.) is important to battery longevity.
Another good point is the difference between sport and competition flying. I fly a lot, but it's ALL sport flying, so I don't have to push my equipment to the limit nor do I have to worry about a few percent of lost power. Perhaps that viewpoint is what really makes the difference.
It's interesting, though, that electric is growing in the competitive C/L Stunt segment. The consistency of performance was one of the points that was made to me by one of my friends who competes there. No CG changes, no needle changes, etc.
Andy
#307
Right now we have mostly glow some gas and some electric guys at our field, And to me we can share the same air space not a problem, The thing I notice on a pretty regular basis is the lipo batterys puff out so far they look like they are going to explode! And hearing well that one's garbage now! Honestly I have no interest in electric! one reason the batterys just do not seem reliable, I would miss the noise here the noise is really not much of a problem, I love tinkering with the glow engines and I would miss the smell of the glow fuel! Pattern planes to me need a glow engine up front to be the pattern plane I remember! Where there is a problem with noise then I reckon you got to do what you got to do to fly!
#308
MN
ORIGINAL: bem
Hi,
- I know the air intake on carburator could be silenced with a ''muffler'' type thing.
- You could ''soft'' mount the engine with rubber holders.
- Cut some of the propeller tips since they make noise and contribute not much to thrust anyway.
- Use a long stroke 2-stroke engine (usually) to use larger props that do not need to rev as much and therefore give less noise.
More?
/Bo
ORIGINAL: TonyF
More?
/Bo
Ditto!!...................
I would like to see a setup like that....
I
#309
MN
ORIGINAL: grcourtney
Gary
Gary
I think the main thing is the "type of noise" that comes out of the plane...
4-strokes could be equally the same dlbs out of the exhuast, yet the 2-stroke sound, seems to be more irritating that the
4-stroke sound.
Prop noise is also a issue...
A two stroke (especially the .60 and less) require HIGH RPM to get the power out of them...7,000 4-stk vrs. 13,000 2-strk RPms or around there...
THis then equates to LOUD PROP noise.
Which can be Very irritating to home owners....
ALSo....
Muffled and Quite Pipe, is a BIg difference in sound, price, and performance.
I have a MUfled pipe for my OS 1.20 AX swinging a 17x6 APC 10,000 RPM's on the ground.
Much louder than my saito 1.25 w/ a apc 16x6. Runs less RPms as well though...
The Quiet pipes are great, but exspensive to make and pricey... 150$ Vrs 75$ for a Muffled pipe...
These prices are for the 15-26cc size though.
A Muffled Tuned Pipe is an un-muffled tuned pipe with a muffling can added over the back cone.
An un-muffled Tuned Pipe is a two-cone chamber with out any restrictions other than the back cone and the end stinger.
A Quiet Tuned Pipe or a Single Quiet Tuned Pipe is a chamber with baffles that tune the system and quiet the exhaust. A Quiet Tuned Pipe is quieter then a Muffled Tuned Pipe. A Double Quiet Tuned Pipe, as seen at the bottom of the Marine Tuned Pipe page, is even quieter and can be used on airplanes.
(Macs website)
#310
You just buy a silenced or quite tuned pipe! Though a three blade prop would also help.
http://macspro.com/tunedpipes.asp
#311
Sport_Pilot,
Good information - notice that Hangar 9 in their accessories list for Phoenix 7 ARF has a MAC "Muffled" tuned pipe listed (MAC1250). So keep that in mind - if you want or need a quiter pipe on that plane buy the"Quiet" tuned pipe instead (orthe "Double Quiet" tuned pipe).
/Bo
A Quiet Tuned Pipe or a Single (Q)uiet Tuned Pipe is a chamber with baffles that tune the system and quiet the exhaust. A Quiet Tuned Pipe is quieter then a Muffled Tuned Pipe. A Double (Q)uiet Tuned Pipe, as seen at the bottom of the Marine Tuned Pipe page, is even quieter and can be used on airplanes. Most of the Single (Q)uiet Tuned Pipes, shown on this page, can be made in a Double (Q)uiet version
/Bo
#312
You will still have the problem with prop noise, but the quite pipe should be well under 98 Db which would be enough for me. But a three blade prop would bring the noise down further, especially if it loads the engine slightly more than the two blade prop.
#313
MN
I will have to post this in the engine forum, but I have had a hell of a time running my piped glow engines of late...
I have the muffler pressure tap midway on the pipe, but it seems this isn't a reliable method.
I may have to tap the header directly off the engine.
After pan caking my Reactor in the 1st 2-min of the flight...Due to dead stick I have
had ENOUGH, of 2-stroke engines and pipes.
I even spent couple of tanks on the feild making sure it was reliable....Problem was, I didn't run the WHOLE tank.
I would only run 3/4 of a tank, and refuel, thinking the problem solved, when it reared up @ 1/2 tank....
Be at mid throttle, go to high, "rrRRRAAppaHh"
That was it...
...ERRRRRggggg[:'(][>:][>:][>:]
2nd plane in 1-week due to lamo, mistakes...
69"yak.... WING departed in a spin, due to the screws vibrating loose!.
And now the reactor, with a ST .51 piped.
I have had enough of these glow engines, in general....
I would like to see these with an ignition and or gasoline with a pumped carb..
Perhaps, I have to run pumps when I have a pipe on...
I don't want to run WOT, all day....
It will piss the neighbors off completely...
I have several NIB 4-strokes, so that is where I am going with these things...
That was it...
#315
PA
ORIGINAL: kochj
Be at mid throttle, go to high, ''rrRRRAAppaHh''
That was it...
That was it...
#316
The factor that most affects noise is prop size because the prop dictates the RPM. It's also the cheapest way to reduce noise :-)
To silence a piped .61, here's the list of tricks I know of:
- Prop: no less than 12x11, get the RPM way down (use long stroke engines)
- Tuned pipe: Use a three-chamber pipe. I love the Hatori #650 (Use #700 for long stroke engines). Bolly pipes work also
- Tape the pipe. Seriously. Gaffa-tape it the whole thing, dumb it down. It works.
- Eliminate intake noise by taking air via a soft tube into the fuselage (drill a hole in the firewall and route the carb air from there)
- Prop noise - APC is pretty good. I think carbon and wood props are louder but that may be just me
- Soft mount the engine and pipe
#320
My Feedback: (10)
TN
<entering the box. . .>
.I heard they are being shipped in the same container as the 2M Vanquishes. . . .
<exiting box.="" the="">.<exiting the box. . >
</exiting>
</exiting>
#321
MN
ORIGINAL: klhoard
<exiting box.='''' the=''''>.<exiting the box. . >
</exiting>
</exiting>
H9 Actually shows the plane (finished) and gives a backorder option.., and gives a reasonable arrival date....
(not, sometime in the near future)
Did you really need to bring that up..??
It's like BOOST tab, I mean "BOOB TAPS"...
#322
My Feedback: (10)
TN
yes, best installed with "TITBOND" aliphatic resin glue. . .
OK, I'm now going to report myself to Handglider the Moderator. . .
</exiting></entering>
ORIGINAL: kochj
<entering box.="" the=""><exiting the="" box.="">
. . .<snip>. .
. . .<snip>. .
#325
KY
Guess I've been out of the loop but just saw the advertisements about the new Pheonix 7 ARF. This is so awesomel! My dad had a Pheonix 7 around 25 years ago but he never built it. I actually wrote Mr. Lowe a letter when I was about 10 years old asking how to build it and he responded! What a great guy to entertain a 10 year old kid with silly questions about how to build one of his planes. Anyways, I ended up owning a Pheonix 9 a few years later, there is nothing like an old school pattern plane.
I'll have one of these for sure
