If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 28 of 38 FirstFirst ... 182627282930 ... LastLast
Results 676 to 700 of 929
  1. #676
    R_G's Avatar
    Join Date
    Dec 2004
    Farrell, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Scoop! Hangar 9 Phoenix 7...ARF!!!
    Ralph Geese, AMA 36403, NECPO #2
    Wanna hover? Fly a heli!
  2. #677
    Join Date
    Aug 2006
    Roswell, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe, thanks for the great laugh this morning. Of course like most of the regulars here I blocked Cees' babble long ago and can't see what he wrote. But I can guess. Let's hope he provides us the opportunity for you to reply like that again. I hope you will be up to the task if he does.
    David
  3. #678
    Join Date
    Nov 2005
    Farmington, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I too got a hardy laugh from that reply! I'd like to see more! Thanks!
    FB
  4. #679
    KLXMASTER14's Avatar
    Join Date
    Jun 2007
    Simi Valley, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JoeMamma
    Hey Cees, your response sounds like Einstein's β€œFear of Relatives” to me !!
    The actual problem is that the turbo-encabulator is simply not oscillating at a required weekly frequency. Check this out by using a tuning fork. Simply tap the tuning fork and hold it to your forehead.
    This oscillation causes both of the wires to free-wheel and will cause the tribbal-valve to oscillate at at even higher frequency. This is too bad, because with high frequency at its max, the max may not be enough ! Although the wires menstrual cycle may be at a disadvantage, any advantage can be adjusted by trivvilating any other adjustment !!
    Adding a non-supporting set of freeloading wire supports may exasperate this condition !! This can be easily tested with either an AC volt meter or an accurate blood–pressure tester.
    Also, high amperage of the deadly kind may be experienced with ANY 220 or 440 volt retract system when using extension cords of any kind. This problem can be easily resolved by increasing the size of both the wires to 8 gauge. Please guys, DO NOT use your tongue when testing any 440 volt systems !!!
    Bottom line..............the silicone-in-a tube should work.....signed, Professor Erwin Corey.
    Joe M.
    I never thought to check the Turbo Encabulator.
    Thanks.
    West Coast Regional Director- Classic Pattern Association
    Team Tailwinds
    Ultra Sport Brotherhood #162
    2014 NSRCA District 7 Advanced Champion
  5. #680
    speed-panzer's Avatar
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Besides that broken wire soldering, are there more issues with those E-Flite retracts?
    I am considering to try them. Never been fully happy with pneumatics or conventional mechanical retracts.
    Electric systems sounds to me to be the technology you ought to have today.
  6. #681
    Join Date
    Aug 2009
    North Aurora, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JoeMamma
    edit
    Holy crap,I get it now!That was a Cees-section! Or was it a Cees-sation! Oh well........
  7. #682
    Join Date
    Nov 2002
    Hobe Sound, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pneumatic's work fine, set them up right, they will take care of you.
    Crank
  8. #683
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Lenox Township, Michigan
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: speed-panzer
    Besides the broken wires, I haven't had any other problems with the EFlites, so I guess you could say I'm satisfied with them.
    As a matter of fact I recently ordered sets numbers four and five........one set for a Hangar 9 Jackal and one set for an EFlite Habu 32.
    Joe M.
    Joe Mamma
    There\'s no such thing as gravity.........the earth sucks !!
  9. #684
    Join Date
    Nov 2002
    Hobe Sound, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We flew P-5's & 6's, like a lot of other guy's, decade's ago. I recently gave one of my built P-6's to a friend up in Ohio. We all hung out with Dave B. in those day's, and of course, copied everything he did, (except flying skills)
    Jack was having problems with the CG in the 6. I asked him to ask Dave, here is what he wrote back. Dave flew P-5's and P-6's before everything else. The below explanation was our guideline each time a new Phoenix was set on the runway, alway's worked fine. No slide rule's, balance machine's, etc. Just common sense.
    Understand here, the placement of the main's, servo's, tank, battery pack, etc., may not allow this explanation of CG. It worked for our set-up at the time.
    Crank
    To: Jack Anastasia
    Cc: VinTerrV
    Sent: Tue, July 5, 2011 12:29:10 PM
    Subject: RE: Hey Jack, Vince
    "without fuel, if you push the tail down, it should stay down: with
    fuel, if you pushed the tail down, it should right on the nose wheel!"
    This is the way I checked the balance point.... It will be pretty
    damned close....
    More in either direction would be a matter of personal preference....
    Dave
  10. #685
    edp's Avatar
    Join Date
    Nov 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just got back from the field and that is the way mine is set up. I did have to add 3 oz. to the tail but now it is neutral while inverted. I also have the stock tank and have had NO fuel problems w/ my Webra Speed .61 in the nose. I am nowhere close to the manuals throws.
    Ed Peel AMA 2680 NECPO #58
    Wayne County R/C Club
  11. #686
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe,
    where do you buy the E-Flite retracts? Tower doesnΒ΄t list them...
    Dominik
  12. #687
    Join Date
    Nov 2002
    Hobe Sound, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not Joe here, but Horizon Hobby.
    Crank
  13. #688
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe,
    Dominik
    Make sure you get the 60-120 size. http://www.horizonhobby.com/Products...ProdID=EFLG430
    Joe M.
    Joe Mamma
  14. #689
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Found some sources here in germany, too.
    Do you operate the retracts at 4.8V or 6V? Do you use a separate battery for the retracts?
    Dominik
  15. #690
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Dominik
    Dominik,
    I didn't use a separate battery for the retracts. I'm using a 5-cell 6-volt JR 1400 mah NiCad to power up everything.
    An important note: Just remember the electric EFlite's are NOT a drop in installation for the Phoenix 7 and will require some extra work to get them to operate smoothly. The Phoenix 7 is currently set up for Robart pneumatics.
    The extra work was worth it ![8D] I don't like using dual cables or wires for steering, so the biggest challange for me was to use a single, solid 4-40 wire between the EFlite steering linkage and a separate steering servo.
    Joe M.
    Joe Mamma
  16. #691
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: dhal22
    My response to Cees at post #673 must have chased him away for good ! For more good laughs, do a word search for Turboencabulator.
    Joe M.
    Joe Mamma
  17. #692
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK.
    A little of topic - I would plan to use the E-Flite retracts on some other plane, a Flair Lightning. Hot ship, will be powered by a small block Novarossi .91 rear exhaust.
    I do have 2 sets of Robart 520 series in operation, flawless so far. But IΒ΄d like to try the electrical ones!
    Yes, routing the cables for the pull-pull steering of the nose landing gear always causes some intensive brainworking...
    Dominik
  18. #693
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh well..........they say every airplane has an expiration date. Mine was today.
    Been flying my Phoenix 7 all summer. What a nice aircraft.
    Part of my fleet also includes an 80” SIG Four Star, a Hangar 9 Pulse 125, a Hangar 9 Twist and an 82” Great Planes Super Sportster. You can get any of these low and slow in a tight turn without any problems. But, THAT IS the problem. I’m just getting too used to flying my low and slow flyers.
    Crash was 100% my fault. I was setting up for a landing on my Phoenix and got her WAY too slow in a turn that was WAY too tight. She rewarded me by falling out of the sky..........splat.
    She’s too badly damaged for any repairs, so it looks like I’ll be getting another one for a winter project.
    Joe M.
    Joe Mamma
  19. #694
    Join Date
    Nov 2004
    Naperville, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Shame! It says a lot for you to like it enough to get another one. After all of the complaints I've read about the Hanger 9 P7, you must have been satisfied.
  20. #695
    Taurus Flyer's Avatar
    Join Date
    Jan 2004
    Almelo, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JoeMamma, you write:
    maybe something to think about, it's 2011!
    see picture :
    To fly my Taurus, also in β€œwindy conditions” I can switch over to cruise control.
    Position 3 manual throttle operation as normally.
    Position 1 airspeed control.
    Trim lever of throttle stick in max position and stick lowest position is lowest useable air speed. Two clicks more of the throttle stick is absolute safe airspeed in all conditions.
    Position 2 as position 1 "airspeed control" but switch over to manual on moment of touch down.
    My airspeed controller prevents flying below stall conditions in normal circumstances.
    Cees
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  21. #696
    JoeMamma's Avatar
    Join Date
    Nov 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JoeMamma
    Joe M.
    Couldn't bare to be without it, so I picked up another Phoenix 7. One thing nice is I'll have all winter to get her finished.[8D]
    I'll just need to repeat this 20 times..........this is NOT my slow, gentle flying Pulse 125, or my Twist or my Four Star...........DON'T get her too slow in a turn................DON'T get her too slow in a turn.....
    Joe M.
    Joe Mamma
  22. #697
    Join Date
    Jan 2004
    Almelo, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe,
    Maybe a better idea:
    ...........DON'T try to land without a decent circuit.....
    Because, that's the only way to prevent a thight turn on low altitude before start the final approach!
    Especially on low altitude and flying downwind it often seems the plane is flying too fast. When you throttle back the engine and short after that also want to make a (180 degrees?) tight turn it can be end of story.
    It's a pity that with all that 2.4 GHZ, telemetry, and digital computer radios, you still cannot buy a simple stall warning device and keep in mind the high speed of modern servos even can be a disadvantage in these situations especially for the ailerons!!
    Cees
  23. #698
    Join Date
    Aug 2006
    Roswell, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had to learn that lesson the hard way myself years ago. I've never forgotten.
    David
  24. #699
    Join Date
    Jun 2007
    Simi Valley, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Joe,
    Glad you are back! Her is a practical tip to help keep your aircraft out of that hole in the ground: The angle of attack is what stalls the wing, not the speed. Set up your low elevator rate such that the aircraft will not stall with full up elevator. Landing with elevator rates high enough to stall or spin is asking for trouble.
    The elevator position sets the airspeed, use the throttle to control your rate of decent. Put this into practice (just like full scale) and your landings will be 10's.
    This is from someone who- you guessed it- learned the hard way.
    No fancy Turboencabulator device will keep a pilot from pulling the nose too high if it is available.
    Good luck!
    -Robert
    Team Tailwinds
  25. #700
    Join Date
    Jan 2004
    Almelo, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gents, an example about fixed wing training, and the importance of airspeed.
    WWW, Pilot friend, fixed wing training.
    Many stall/spin accidents have occurred in situations, such as crossed control turns from base leg to final approach (resulting in a skidding or slipping turn); attempting to recover from a high sink rate on final approach by using only an increased pitch attitude; and improper airspeed control on final approach or in other segments of the traffic pattern.
    Flying a classic pattern plane isn't flying a trainer, they are designed to fly a very accentuated spin, observe the airfoils for example. When by coΓ―ncidence there are spin conditions, by pilot input or external influences, he will do for what he is designed for! Spin.
    Prevent these conditions occur is main goal of the pilot by training, observing and control and IMO not limiting the capabilities of an airplane or making the piloting more complicated by switches.
    Flying a decent circuit is most important, observe compenstation for drift, divide the circuit in (ground related!!) turns of no more than 90 degrees, maintain a safe airspeed, maintain altitude to recover from a spin if possible!! Recovering from a spin in the turn to final did happen me ones with my Orion, it was a matter of parts of a second!
    Cees
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
