If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 32 of 38 FirstFirst ... 223031323334 ... LastLast
Results 776 to 800 of 929
  1. #776
    edp's Avatar
    Join Date
    Nov 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Scoop! Hangar 9 Phoenix 7...ARF!!!
    FB,
    I'll take pics tomorrow as the bird is packed up in my truck. A gusset was added underneath and epoxy and milled fibers were added to the joints. They survived the hasty landing w/o damage.
    Ed Peel AMA 2680 NECPO #58
    Wayne County R/C Club
  2. #777
    edp's Avatar
    Join Date
    Nov 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FB,
    I found these from a post I placed a while ago in a P7 assembly forum.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1747489   Click image for larger version.
ID:	1747490   Click image for larger version.
  3. #778
    Join Date
    Jan 2002
    Stanford, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ed, thanks for sharing the photos! Your install looks great.
    Where is this P7 assembly forum?
    Matt
  4. #779
    edp's Avatar
    Join Date
    Nov 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
  5. #780
    Join Date
    Jan 2002
    Stanford, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks! looks like a familiar thread on RCG... Lots of good info!
    Wonder if Robart will come out with electric retracts for the P7 at Toledo this weekend? [8D]
  6. #781
    Join Date
    Jan 2002
    Stanford, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ed I just noticed from your earlier photo on the Webra post... is that an Enya 60XF-4 I see in the Intruder in the background? I am a big fan of Enyas too and have various versions in collection. Been thinking about using the pumped one for the Phoenix, but they weigh almost as much as the OS-61SF-P.
    Anyone using the 61SF-P and how did it balance out?
    Matt
    ORIGINAL: edp
    Here is the bullet I put in my bird. It is a Webra Speed .61 with the Mac Black Pipe. I have had no problems w/ the fuel tank location at any rpm range. I have another one to put in my Deception that is in the glassing. Both are NIB engines. We don't have anyone using the new EVO engines yet in our area. I did check my rudder and it is still nice and tight so thanks for the heads up on that!
  7. #782
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Huang
    Matt
    ORIGINAL: edp
    The Phoenix 8 was designed to be flown with the OS .61 FSR size and style of engine. Back then we would just stick a Robart pump on the engine and plug away at flying. None of the small block, modern, reduced size, light weight alleged 60s make that kind of horsepower.
    Ed Cregger
    \"Practice makes prefect\"
    Saito Club Member #52
  8. #783
    Join Date
    Dec 2007
    New Hartford, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: NM2K
    ORIGINAL: Huang
    Matt
    ORIGINAL: edp
    Ed Cregger
    Right...which makes you wonder why they just don't make the OS .61FSR, Hanno, Webra Speed .61 etc. any more. Some of the change in engines these days is just change for change sake. I mean, tell me what was wrong with the Hanno in the grand scheme of things that would indicate the motor should be discontinued? Crazy... Also, at the end of the day some of these new "60's in the case of a 40" just get nuts when you put them in a 40-sized plane (prop clearance, tank size etc.). Kind of nice going the other way though
    Tis what it tis....60 degrees tomorrow. I'm leaving work early to fly!
    Tom
    If I say "what?" she says "I'm deaf!"; if she says "what?", then she says "I mumble!".
  9. #784
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I'm not saying that things should stay the same. After all, I remember when the schneurle ported engines first came out. What a serious increase in horsepower that was in those days. But there seems to be some belief that the new smaller format ".60" sized engines (few are actually 10cc of displacement), are so advanced that they outpower the old timey 10cc pattern engines. I have yet to see it in reality. I put my modern 10cc engines (small case) in .40 to .50 sized models and enjoy the surplus power and the ability of swinging larger props than their .46 sized counterparts.
    After all, we're just talking here.
    Ed, NM2K
  10. #785
    edp's Avatar
    Join Date
    Nov 2002
    Canton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Matt,
    That is a Bob Smith all glass T2A I'm finishing.
ID:	1749395   Click image for larger version.
  11. #786
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, Ed, I can assure you that the Evo .60NX exceeds the power I got from .61 F-SR's back in the day. My first real pattern model in 1976 was a P-6 with the, BTW, "Perry" pump, not Robart, and the Perry pump carb. They would barely turn a Rev-Up 11x7.5 at 14,000. My Evo turns an APC 11x7, a prop with much more load then the Rev-Up, at an easy 13,800 to 14,000. And I haven't checked it yet for RPM with the Perry pump and carb on it. It sure sounds faster.
    Now I haven't yet totally sorted out the pump installation on the Evo. Plumbing it with a return line as posted in this thread did help the mid-range quite a bit. I need to fly it some more to make sure it's a working solution. But if it doesn't end up being the solution, I do have a NIB O.S. .60F-SR w/Perry pump and carb I could stick in it. Using the .60F-SR is a little scary because we broke shafts on those. The .61F-SR went to a bigger diameter shaft to solve that problem. Lucky for me I have the parts to convert my .60 to a .61F-SR. Or maybe the NIB YS .60 I have. I'd have no problem using these if I need to. Just can't get any parts for them.
    BTW, the P-8 was a lot easier to get the tank in line with the carb. That's why they put the little sccop on the bottom of the nose of a P-8 vs the nose of what we're talking about here, the P-7.
    TonyF - Team Horizon, Team Contra Drive, Neu Motors
  12. #787
    Join Date
    Jan 2002
    Ringgold, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: TonyF
    Well, Ed, I can assure you that the Evo .60NX exceeds the power I got from .61 F-SR's back in the day. My first real pattern model in 1976 was a P-6 with the, BTW, ''Perry'' pump, not Robart, and the Perry pump carb. They would barely turn a Rev-Up 11x7.5 at 14,000. My Evo turns an APC 11x7, a prop with much more load then the Rev-Up, at an easy 13,800 to 14,000. And I haven't checked it yet for RPM with the Perry pump and carb on it. It sure sounds faster.
    Well, TonyF, if you are who I think you are, your word is good enough for me to buy said Evolution and give it a try.
    I never had much luck with the Perry pumps and carb setup. I preferred the Robart pumps and stock carburetors. The OS .61F-SR came with a reducer in the carb. No big optional third party carb was necessary with the Robart pump and this particular engine's carb. But you knew that.
    Ed, NM2K
  13. #788
    Join Date
    Jan 2002
    Stanford, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ed I love the all vintage 60 big case short strokes too! (especially when bore x stroke = 24x22mm like the YS60, 60FSR, Enya 60XF etc.) they are just sweet. But the modern small case 60s are significantly lighter, and there's definitely nothing wrong with trying to go lighter, right? If the big case 60s will require tail weight (or surgery to move components back) on the P7 I would prefer the lighter engine.
    Power-wise it depends on engine. The Jett 60 I have turned great numbers from its small case. Was considering this for P7 but it will likely have same fuel draw issues. The Evo also seem to be turning good numbers from small case. Coincidently the 60NX is 24 x 21.5mm for bore x stroke, fairly close to what we had, with even shorter stroke. I've yet to see one run. Will see how Tony's setup turns out with pump.
    On the classic engines YS-60FS is a great fit. It isn't as heavy as the 61SF-P (plus the SF is a long stroke) and it screams on pipe. But it isn't available anymore. [] That's why so many are using the 60NX, it is available and no need go wondering on ebuy everyday
  14. #789
    Join Date
    Jan 2002
    Stanford, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    edp: Beautiful plane!! =D
  15. #790
    Join Date
    Nov 2002
    Hobe Sound, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A fully equipped Horiaon ARF P-7, with the electric retracts, total weight ? 7.25 - 7.75 lbs ? Travel back to early '70's, fully equipped P-6, total weight, 8.0+ lbs. ? The Super-Tigre G-61's, then the OS 61's, plus the 61 SF, were torque monster's. I am not sure if you put this Evolution 60 on an 8+ lb. plane, is going to do the job. Tony, you should be able to give us the best opinion on this.
    Crank
  16. #791
    Join Date
    Oct 2010
    Bradenton Florida
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks Like Great Planes Has Joined The Likes Of Horizon Hobbies, & Ressurected TheirClassic Pattern Plane.....
    THEDIRTYBIRDY60
    YEAH !!!!!
    Manual - http://manuals.hobbico.com/gpm/gpma1975-manual.pdf
    Website - http://www.greatplanes.com/airplanes/gpma1975.html
  17. #792
    speed-panzer's Avatar
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very cool, I have always liked the soft lines of BridiΒ΄s planes.
    This Great Planes poduct video is done exactly the way you think that kind of plane needs to be flown. Well done!
  18. #793
    Join Date
    Feb 2012
    HortonAlabama
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Phoenix 7 how will a YS 60 FR for work this airplane?
    Tim
  19. #794
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I just got in 5 flights today with the Phoenix 7/Evo .60NX at Bear Mountain getting ready for the contest the weekend after this. The Perry Pump is working great now that I plumbed it with the return line as posted here a while back. I really don't know why it works, but it really does. I have a Perry Pump Carb from my O.S. .60F-SR on the engine now but I may try the stock one just to see if with the return line it will work.
    I'm running an APC 11x7, 15% Coolpower fuel and a Rossi R-8 plug. Before I put the R-8 in it was popping a plug every flight. And that was with an extra head shim installed. The original R-8 flew the 5 flights today and is still good.
    This set-up is making very good power. More then I have had before because now I can get a much better needle setting without it going lean at times. The model is moving right along and is really flying well. Chip Hyde got a couple of flights on it today and he was impressed. If I had a P-7 fly like this in 1977 I would have been king!
    I will post pics of the installation when I get the camera unloaded. It is an unusual installation but it is working well. Thanks to the forum for the return line tip! It got everything working.
    Hope some of you can make it out to Bear Mountain on April 28th and 29th. Along with regular AMA Pattern Chip has got some great stars coming out to fly Classic. Myself, Jim and Matt Kimbro, Richard Verano, Rusty Van Baren and a real special guest. Joe Bridi is planning on coming out. Should be a blast!
  20. #795
    Join Date
    Jan 2002
    Carrollton, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I posted the return line thing...I have not figured out the logic behind that either but it worked. The only thing that I can think of is the carb uses what it needs, then extra pressure/volume is bled back to the tank via the return line making it almost like an 'on demand' delivery system. Higher RPMS use more and return less while, low rpms use less and return more which is what makes it work in the midrange of our engines.
  21. #796
    Join Date
    Feb 2008
    kuna, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    jeff
    yes the return line, is intended to be smaller so to retain adequate pressure, modern auto engines us this type of fuel return on injection systems.
  22. #797
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got in 5 more flights today. I switched to an 11x8 APC and boy did it come alive! The set-up is turning that prop at 14,200 set to the flying needle valve setting and it is moving along! I did put in a Rossi R-5 plug and that seems to work well. It is just too much fun, if there is such a thing. Should be a blast at the upcoming Bakersfield contest.
  23. #798
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here's a pic of the pump installation. If I started fresh I might be able to come up with something cleaner, but this is working.
  24. #799
    Join Date
    Nov 2004
    Rennerod, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finally, a photo, thanks. Now I understand the T-fitting to return the excess fuel.
    Now we need some more details, what pipe and and what pipe length from glow plug to baffle are you using? What kind of fuel?
    What bore ID size has that nice old Perry carb? Is that a filter thingy on the carb opening?
    14.200 on 11x8 APC is really good.
  25. #800
    Join Date
    Feb 2003
    Darwin, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey you Mob
    I need to buy a Evo .60 now but were.
    Thanx CrocEnd
    PS none in Aussie
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
