Scoop! Too early to release information.
#151
RE: Scoop! Too early to release information.
ORIGINAL: bjr_93tz
Is it just me or does the horizontal stab on the ''original'' look a lot bigger than on the reproduction? The distance from the leading edge of the stab to the leading edge of the fin is very different.
You can see this in that side view pic. Extend the line of the fuse top deck past the stab on both models, and compare.
Also check out that three quarters rear view pic. You can see that the original has more anhedral on the stab and the stab root is set higher.
The actual size of the stab seems to me to be about the same.
I guess that keeps the centre of the side area of the stab at about the same height on original and reproduction Curare, which makes sense if they wanted to reduce stab anhedral without affecting other qualities.
They seem to have kept the wing dihedral the same, so all they have done is reduce the effect of the stab anhedral without affecting much else.
The effect of the stab anhedral is to provide a roll-in moment with top rudder in knife edge, to counter the roll-out moment from the wing anhedral, without transmitter mixers which didn't exist when the original was designed. So if the reproduction requires less roll-in from the stab in knife edge, all else being kept pretty much equal, this means the reproduction has a higher centre of gravity than the original. This might be because the original was designed and set up with a tuned pipe weighing about 200 grammes hung under the fuselage, while the reproduction is designed for electric power or i/c power without a tuned pipe.
Best regards,
G.
#153
ORIGINAL: gkaraolides
...They seem to have kept the wing dihedral the same, so all they have done is reduce the effect of the stab anhedral without affecting much else.
I used to fly mine with a .75 turning an 11x9 or 11x10 prop and it flew great. Fit a 12x6 and it'd grunt around a knife edge loop, but apart from pulling huge verticals it was pretty much a dog to fly so I'd expect the type of props the electric crowd like to run might require some airframe tweaking. Have just fitted a Scorpion HK-4035-400 running 10S on an 11x10 prop and happy with the initial performance (only 1 flight) but very unhappy with the vibration from the motor. I sent it back to them and have just received it back so I'll put it back in tonight and see if the vibes are still there.
Mine's 20yo now, full of oil and I'd love to build another as they're a beautiful plane to fly.
#154
I always wanted to a Curare to have a unique plane at the field. Sure looks lighther than the 1/4" sides and blocks in the original plans.
Jim
Jim
#158
ORIGINAL: hrdflite
i want a set of wings of the bottom of the stack ,should be nice and straight.
I was thinking the same thing.
#159
ORIGINAL: hrdflite
#160
Does this company have a license to build and distribute the Curare? If not, I don't think I would be buying one. If you can't download music from the internet without paying the royalty, why should this company sell Curare's without paying the royalty?
Any comments?
Frank
Any comments?
Frank
#161
QC, CANADA
Frank,
Hanno and the developers are intimately involved. They live close to each other in Austria (if not in the same town). I believe Hanno shopped often at the developers store - hence the project.
This ARF is fully blessed by him. Check out the Facebook () pages - a lot of the project background is (or at least, was) there.
I wonder if this ARF is successful if they'll follow suit with a Magic or better yet, a Mystic or Sensation!
I'd buy a Hanno approved Mystic 60 ARF... I have the perfect engine and pipe for it, the Hanno RF-P, waiting downstairs for it's wings!
David
David
#162
If sales take off, I'd love to see someone on this side of the Atlantic remake the Tiporare or Illusion pattern plane as an ARF.
#163
ORIGINAL: countilaw
Any comments?
Frank
Any comments?
Frank
However if sombody is worried that the designers from other countries that ripped off the Curare (or at least some of it's features) and sold it under different but similiar sounding names back in the 70's aren't getting their "cut" then by all means, ask the questions
#164
QC, CANADA
ORIGINAL: ShinySteelRobot
Also, covering a Tipo or Illusion wood fuse is a bad proposition. I discovered this from doing it on a little one.
Having said that, glass Tipo's and Illusions exist as ARF's..., they just need a little paint before flying...
David
#165
Hey , I was just asking the question. If Hanno is involved, then it's great. I just get concerned that so many people have put so much into this hobby, and then someone comes along and rips off thier ideas or takes advantage of the original designer's hard work.
I didn't mean to appear petulent.
Frank
Frank
#166
QC, CANADA
Frank,
I see where you're coming from. For these Austrian developers to go ahead with a Curare ARF and not involve Hanno would have been adding insult to injury. One thing's for sure, there have been and continue to be so many iterations and kits of the Curare in different forms that I've lost count. I wouldn't be surprised if Hanno also had.
Stopping "kitters" of the Curare is like trying to stop the DVD movie replication business - it's everywhere. The good news is that we don't want it stopped...
David
David
#169
[quote]ORIGINAL: hrdflite
QUALITY LINE KITS CURARE , IS ALICENCED PRODUCT.
[/quote
Hrdflite, I can't wait to get my hands on another Majic from Quality Line Kits. I was able to get an original Header from Singapore with the help of another member here on RCU. Picked up a pipe for $15 from a LHS and retracts from Ebay. Now I'm just saving money for the plane. The first Majic I got from QLK was fantastic, take that back, it was Majic.
Frank
#170
ORIGINAL: doxilia
Frank,
Stopping ''kitters'' of the Curare is like trying to stop the DVD movie replication business - it's everywhere. The good news is that we don't want it stopped...
David
Frank,
David
What a wonderful problem to have. I wonder if he's astounded that 36 years later the curare would still have a cult following? Never in his wildest dreams I'll bet.
#171
Hi, I have test flown the Curare ARF in Austria a few weeks ago. I can confirm it is not only endorsed by Hanno, he is the mastermind behind the project. Both Hanno and Schweighofer have tested the pre-production models extensively, with glow and electric power, and the delay (should have hit the shops a year ago) is in part due to the testing and subsequent change orders. The ARF model is based on the MK Curare 60 drawings.
Hanno has spent a lot of time with setting up his electric version, and plans to publish his own settings for all control surfaces including the flap/elevator mixes, dual rates, expos, CG and so on, so everyone can start with a perfect setup. One thing that was only recently discovered was that there is a difference in knife edge mix between electric and glow setups. Due to the battery position above the centerline, a slight increase in dihedral is recommended for electric setup.
The ARF has a very nice battery tray/hatch functionality, and also accepts glow engines with or without pipe with no modifications. It has a fully sheeted wing and stab, and it's beautifully built and covered. It is reported to weigh half a kilo less than the original.
#172
Which one is the original prototype? The photo indicates the bluetrimed oneis, but your e-mail said it yellowed, but the green trimed one appears yellowed.
#173
QC, CANADA
ORIGINAL: Sport_Pilot
Which one is the original prototype? The photo indicates the blue trimed one is, but your e-mail said it yellowed, but the green trimed one appears yellowed.
I don't think the blue trim covered ARF would be an "original prototype" of the ARF at this stage of development. It could very well be the electric model that Hanno has been setting up and that Jon refers to in his post above.
David
#174
In the old/new comparison photo, the orange/green is one of the TOC Curares. The Circus Circus stickers are obvious enough, but you can also see a dark spot on the inner part of the wing where speed brakes protrude out from both top and bottom. He had lots of different version, one was for Springfield WC, one for South Africa, and the TOC versions. Differences were airfoils, brakes and spoilers. The blue/orange is Hannos electric ARF.
