Pattern Bird SL-1 LA-2? help ID this Plane
1 Attachment(s)
I got this from a club member he got it from a guy that was selling off his late dad's stuff any one have any info on it like CG and how the wing are attached? there is only a hook in each wing do they use a rubber band? it is a Obsession II HELP
RE: Pattern Bird SL-1 LA-2? help ID this Plane
Yes, rubber bands(2) were used to hold the wings on . There is very little force trying to pull the wings out. I normally prefer to use a large "O" ring to hold my wings on. They can be found in many large hardware stores in the pluming dept. I f you can determine where the previous owner had mounted the receiver, battery and servos and also the fuel tank and you mount your equipment in the the same locations, the CG should be correct
John W. |
Thanks i know the tank was mounted with Velcro right on the CG there is a tube in the rear i think for the FM wire there is just some funny plumbing on the oit side of the plane i think it is to fill and vent but not sure how it works
Some detail photos would help a lot
i will get more thanks
1 Attachment(s)
here are some more pictures
1 Attachment(s)
2 more thanks for the help
