YS61RE Classic
Just wanted to thank Richard Verano and William Bartlett for bring this motor to reality. Removed my AR and installed the motor this past weekend - what a monster. Fired right up and idled beautifully. I cut the head pipe to 4" and used the standard Hatori short stroke pipe. When I tell you this motor has power, power is what it has. I didn't have a tach but flying pattern for the last 30 years and YS motors only, I trust my ear. If I had to guess, after 4 tanks of fuel and settings between a good 4cycle and just to peak, 14500 - 147500 would be a safe estimate. Can't imagine what this motor will unload in the existing a split-S. Actually, it was a little scrary herring the motor scream. YS has definitely nailed this one
Will fly this weekend Thanks again Richard and Will for all your efforts and dedication to this hobby.<br type="_moz" /> |
RE: YS61RE Classic
Awesome!!
Back to back comparison of new YS -vs- YS AR on the same airframe...That's excellent: "What a monster" compared to the AR...Now that's impressive!!! What airframe is this in?? Thanks... Chuck |
RE: YS61RE Classic
Hi Auggie,
What prop did you have on the engine and nitro content? Wayne |
RE: YS61RE Classic
Auggie, what prop were you using? I'm guessing by the rpm you might be using a 11x8 or 11x9? Would you have a chance to test it with an APC 11x7?
RE: YS61RE Classic
Where's Kevin?
As the West Coast rep, he might also have some numbers and impressions by now. David |
RE: YS61RE Classic
The prop used was APC 11x 8, nitro content 20/20, McCoy #9 plug. Essentially, I took exactly what I had in the flight box, what I've been using in the past. The airframe is my trustworthy Summit III. This weekend, I'm really going old school - DW 10 1/2 x 7 3/4 balance prop + engine tach.<br type="_moz" />
RE: YS61RE Classic
Auggie I'm sure your Summit is grinning from cowl cheek to cowl cheek. :)
Can you get tach numbers for the APC 11x8 before you take it off? If you can get numbers for an APC 11x7, that would be perfect! |
RE: YS61RE Classic
MY second run this weekend will be with 10%. Running YS60RE short stroke back in the day, I used 5 - 10% nitro. I didn't start using 20/20 until the AR's came out which are long stroke. I think 20/20 would be to much for this motor on a initial run. The pipe/header length are at their max base on last weekends run. I'll play it safe and keep it there. The neat thing about this new motor, the word "Classic" on the head. BTW, the 4" header length I spoke about, came from Richard's trail testing. Richard indicated he was getting 14100-14200 on his runs. My runs seemed only what my ear was telling me and I could be off somewhat. To really get an accurate reading, I'll use a tachometer this weekend. One thing for sure, this motor is every bit of the old school performance and then some. I've also got a Classic in an Aurora - that's next after the Summit
