Curare 60 - Build
Hi all,
I have now had the Curare 60 in a box for a couple of months, so I couldn't resist the temptation to start it. I have to say that parts fit is better than I have seen in any kit and quality of materials is excellent. Will post a few photos as I go. Toying with what engine to use. Any suggestions? |
RE: Curare 60 - Build
Rossi 60-61, YS 60 side exhaust, Werbra 61.
I'm not sure where I get these engines?
Who sells Rossi and Webra? Ari |
Is this a recent re-kitting of the Curare, or one of the vintage kits? I'm curious about how you came across it?
Thanks, Bob |
HI Bob,
I bought the kit through Singapore Hobbies. MK seems to have started kitting some of their more popular planes again. The kit is exactly the same as the old one except some minor details. Ari |
Thanks, I'll look it up!
Bob |
Check here for the Rossi's : http://shop.vendio.com/rossienginesusa
This guy sells them on Ebay also. You can get them cheaper on there. I would go for the 32r60. Click Here for the Webra: http://translate.google.com/translat...D%26safe%3Doff Both engines require low nitro (5%). I would throw both of them on a tuned pipe to get the most out of them. |
Thanks for the links. I have e-mailed to both companies. Look forward to seeing what they come back with
Ari |
Impactiq,
Thanks again for the links. I have ordered a Rossi 60 and a pipe. $281 including priority shipping to Australia. Rossi USA are very responsive and I had a shipping confirmation within hours from transferring payment to them. Seems like excellent service Ari |
1 Attachment(s)
You are going to love the way the MK kit goes together. I built my Curare back in
1982 and It's still flying today. It's like an old friend, lost count of the number flights? Power=OS .61 VF with Macs 8.5 pipe B&D retracts |
Hoping to build my old Curare kit this winter. Was thinking about using a new OS 61 pumped side exhaust motor but now thinking of putting in my used os 61 rf rear exhaust motor after seeing your picture. Thoughts on either motor in this model with a tuned pipe? I'll be using spring air retracts.
The 32r60 is a power house. It will fit the Curare perfect! Get us some pictures of the plane Ari. I like to see the old "go fast" style pattern planes.
Mark |
ORIGINAL: impactiq Get us some pictures of the plane Ari. I like to see the old "go fast" style pattern planes. Mark I'll try to post some photos of the build on the weekend when I have the time Ari |
1 Attachment(s)
Here are some photos of the Curare.
They have changes the flap control mechanism in a way that you now need to carve out for the torque rods if you want to use the original method. They have also changes the aileron servo setup into a two servo system. I am thinking about having a servo for each aileron underneath the wing and a similar system for the flaps. Received the Rossi the other day. Just the same thing of beauty as they used to be!! |
Looking Good!!!!!![sm=thumbup.gif]
If anyone is interested:
I have a brand new, YS 60 rear exhaust short stroke. It has never been out of the box for anything other than to be looked at. I also have two headers to match it (also brand new and unused - Hatori). Let me know if anyone is interested. Chris. |
ORIGINAL: apalsson Here are some photos of the Curare. They have changes the flap control mechanism in a way that you now need to carve out for the torque rods if you want to use the original method. They have also changes the aileron servo setup into a two servo system. I am thinking about having a servo for each aileron underneath the wing and a similar system for the flaps. Received the Rossi the other day. Just the same thing of beauty as they used to be!! Your building looks great! Unless I’m looking at the wing wrong, it looks like you might have the retract mount too far forward though. Shouldn’t the mount be further back to keep a little weight on the nose gear? I like to set it up so the aircraft can rotate easy but has a little weight on the nose gear. You can work this out on the plans by drawing a line from the lowest part of the lower tail forward to the bottom edge of the wheel. Then with a square check that the CG on the plan is just in front of the bottom contact point on the wheel. |
Does anyone have a link for MK Airplane Kits? I'd like to see if anyone imports them into the USA.
Thanks, Bob |
Agilefalcon-RCU, What are you looking to get out of the YS 60?
Hi 8178,
The location of the retract mounts is where it's shown on the plans. There are plywood doublers that interlock with the spars and determine the location. I also thought of this as being far forward but decidd to use the location on the plans. Regards Ari |
ORIGINAL: apalsson Hi 8178, The location of the retract mounts is where it's shown on the plans. There are plywood doublers that interlock with the spars and determine the location. I also thought of this as being far forward but decidd to use the location on the plans. Regards Ari The main gear on my Tipo looks like it is further back but it might just be an optical illusion in your photo. If it helps any, the very outside edge of my retract unit is at a section of the wing that is 11 7/8” front to back. The center of the gear leg would be about 5 1/8” back from the leading edge at that point. The Tipo has an equal taper wing. |
Hey Bob,
you can also get MK kits from Japan (hobby-net), but the exchange rate is CONSIDERABLY more favorable from Singapore hobbies. I highly recommend them. I've bought at least 8 MK kits from them - say 'hi' to Frederick Yong (the proprietor). By the way, you'll get your MK kit usually in 10-14 days from the time you order it (assuming it is in stock). They have had several out of production MK kits available, too. Happy shopping :-) -Will B. |
I whole heartedly second that!
They are excellent and Frederick is extremely helpful. I paid a very reasonable price for my Curare and it included shipping too. From Australia, you get your kits within 10 days or so from placing the order Ari |
Thanks for the advice. I didn't realize that buying from Singapore Hobbies would be so easy. I'll look them up.
Thanks again.... hope that he publishes the price on his web site... Bob |
The YS 60 engine I have for sale is brand new and unrun. It has only been out of the box a half dozen times to be looked at. It is rear exhaust configuration, short stroke and is complete with all manuals. I even have the engine report from RCM.
I would like a minimum of $160 for the engine plus UPS insured shipping (about $10). I talked with Performance Specialties about the engine a year or so ago and apparently they can still support it with most of the parts. Chris. |
When you're building (so nicely) a vintage aeroplane why not go the whole hog and get the correct vintage engine set-up.
Get a Webra .61 speed and pipe. MECOA (Model Engine Comapny of America) have them. Fantastic engine... get on the pipe and wake up the sleepy old Club members! |
ORIGINAL: bla bla When you're building (so nicely) a vintage aeroplane why not go the whole hog and get the correct vintage engine set-up. Get a Webra .61 speed and pipe. MECOA (Model Engine Comapny of America) have them. Fantastic engine... get on the pipe and wake up the sleepy old Club members! |
1 Attachment(s)
Here she is in the bones. My apologies for the photo quality.
Wings are fully sheeted and fuselage rough shaped. Control surfaces hinged and dry fitted. I built wheel wells from scrap balsa and painted the inside white with epoxy paint. The fairings are from balsa blocks and I feathered them into the fuselage with light spacke filler. The frame is very lightweight but strong. I suspect I'll have two retract servos as I don't see how I can easily have the same servo driving the main gears and nose gear. Ari |
ORIGINAL: apalsson Here she is in the bones. My apologies for the photo quality. Wings are fully sheeted and fuselage rough shaped. Control surfaces hinged and dry fitted. I built wheel wells from scrap balsa and painted the inside white with epoxy paint. The fairings are from balsa blocks and I feathered them into the fuselage with light spacke filler. The frame is very lightweight but strong. I suspect I'll have two retract servos as I don't see how I can easily have the same servo driving the main gears and nose gear. Ari Ari, It looks like you are doing a great building job! Life doesn’t get much better than building and flying a Curare 60 kit. The Tipo, Phoenix, Blue Angel, Kaos and taper wing Qwik Flis are pretty great too. All from the era when pattern aircraft were the very best and didn’t all look the same like they do now. The Curare era aircraft fly like rocket ships cutting though the sky like lasers. Sadly, pattern aircraft now-a-days look like they are slightly modified Lanier Stingers with tapered wings. |
Looking very good!!!!!![sm=thumbup.gif];):D
I scratch built one from plans. I have a vintage Webra Speed .61, Macs header and pipe for it too. I did change it from a trike geared to a tail dragger and have been bummed about it since. I may build another to get the trike gear. I cut a foam core for the wing per plans. I did not want to hook up all of the links so I went with 2 servos for the alierons and 2 HS-81MG servos for the flaps.
I am using Airtronics 94102 for the alierons and a 94731 for elevator and rudder. For throttle and gear switch I am using 2 more HS-81MG's. I have had it built for over a year and have yet to get it in the air. The Webra had been sitting for so long I need to replace the front bearing. It is pretty rough buty the rest of the engine is clean. Dru. P.S. I miss the old pattern planes. |
ORIGINAL: blvdbuzzard I scratch built one from plans. I have a vintage Webra Speed .61, Macs header and pipe for it too. I did change it from a trike geared to a tail dragger and have been bummed about it since. I may build another to get the trike gear. I cut a foam core for the wing per plans. I did not want to hook up all of the links so I went with 2 servos for the alierons and 2 HS-81MG servos for the flaps. I am using Airtronics 94102 for the alierons and a 94731 for elevator and rudder. For throttle and gear switch I am using 2 more HS-81MG's. I have had it built for over a year and have yet to get it in the air. The Webra had been sitting for so long I need to replace the front bearing. It is pretty rough buty the rest of the engine is clean. Dru. P.S. I miss the old pattern planes. I would be bummed out too if I made one of these classics into a tail dragger. I’d build a new wing right away before anyone sees you with it (grin). I expect most people realize that tail draggers suck, but they won’t admit it. I’ve got to give you a lot of credit for recognizing your mistake. Thanks for keep the “real” pattern aircraft alive! |
The ONLY and I mean ONLY reason was to save weight. Yea I did save some, but it was not worth it. I will take the weight penalty next time no matter what. The worst part, in the end I was able to save as much weight in other areas as the extra gear and wheel would weight. Just going with the ultra lite foam wheels saved a bunch. Using carbon fiber push rods, 1/8 inch balsa sides and a balsa sheeted foam turttle deck saved the rest.
Dru. |
The Curare you are building is look good. But i wood like to know if you know enyone who might have an mk atlanta.
Johnny,
Check with Singapore Hobbies |
ORIGINAL: 8178 I would be bummed out too if I made one of these classics into a tail dragger. I’d build a new wing right away before anyone sees you with it (grin). I expect most people realize that tail draggers suck, but they won’t admit it. I’ve got to give you a lot of credit for recognizing your mistake. :D:D:D:D:D |
just an FYI - MK did not kit the Atlanta. I believe IMproducts (another Japanese company) kitted it. A great kit - the fiberglass fuse was excellent and the pre-sheeted foam surfaces were very nicely done and STRAIGHT.
-Will |
Link to the MK kits at Singapore Hobbies http://www.singahobby.com/mkp03.html They are very responsive by email.
Is the Curare finished? What about some pictures?
