The "Utopia" ?
Anybody have a copy of the plans for George Albright's "Utopia" .60-size pattern ship (Model Airplane News, March 1973) ? Had a set, once, but foolishly gave them away [:o] )
Has anyone tried building one of these from the plans? |
RE: The "Utopia" ?
1 Attachment(s)
I have them. But, the text is illegible. The outlines and parts patterns are good enough to scratch build from. PM me your email address.
David |
RE: The "Utopia" ?
Thanks for the help. Do you know a firm dimension on the drawing - i.e. the wingspan - so that I can scale the file to the correct size? I'm using a CAD tool (Microstation) that will let me scale a raster file to any size I want it to be.
RE: The "Utopia" ?
The title box says 63 1/2" span which is what I scaled the plans to. The file I sent is full-size and should print out to the correct dimensions.
David |
RE: The
Utopia plans are available through the AMA plan service (800) 435-9262 ext.#507. Plan #60373...$24.00+shipping. Construction article reprint is also available for $4.00.
RE: The
1 Attachment(s)
For anyone not familiar with the Utopia, this is it - from the cover of RCM January 1979.
Ray |
RE: The
1 Attachment(s)
qwerty3,</p> I have the Utopia plan from MAN March 1973 in PDF, scale 1/1. If You PM me You can get a copy. Wingspan is 63 1/4 inch to be exact, according to what is written on plan titlebox in lower right corner.</p> Below some more info for You about Utopia.</p> http://www.algonet.se/~boem/Pattern/...March_1973.pdf</p> http://www.algonet.se/~boem/Pattern/...72_Masters.pdf</p> http://www.algonet.se/~boem/Pattern/..._July_1980.pdf</p> Image 1 and 2 below: Utopia at 1978 NATS. Image 3: Utopia at Toledo show 1978. /Bo</p> |
RE: The
1 Attachment(s)
here are some pics of my Utopia, George's fiberglass and foam kit he produced. Rossi power, tuned pipe rom air retracts.
RE: The
rv7driver,
What a beautiful Utopia - have You flown it lately? /Bo |
RE: The
I've heard rumor of a Utopia glass and foam kit upcoming.<div>Chris...</div>
RE: The
A copy of Utopia Enterprises glass fuselage perhaps?
I suppose rcaiir.com is is going to do it then? /Bo |
