Blackberry Torch and ATT question.
FL
Will one of you fine folks look under "Manage connections" then "Mobile network options" and tell me if you have something like "Preferred connection option"?
Apparently ATT has this option removed from their build of OS6. So what you say. I say well poo. It seems according to Level 2 RIM technical support without that option I will always be charged "data" regardless of Wifi connection or not.
I noticed that if I disable the "mobile connections" and just use Wifi I am still using bits of my data plan. Basically I was lied too. And so where you.
Att is awful. Lesson learned never again.
Regards,
Leonard
Regards,
Leonard
