how important is a perfect wing
making a foam plane, dont have much for proper tools or skills, wanting to know how important is a perfect wing, or will just as close as i can get them be fine?
My Feedback: (10)
RE: how important is a perfect wing
If you saw some of the hacked up looking messes I built and flew early on you would wonder if it actually needed a wing at all. For the most part if you get pretty close to what the designer had in mind it's nothing that a little over powering won't cure.
I would recomend choosing a plane that is well documented by many people as flying good though.
not sure on size of the wing tailskid, is there a rule of thumb to how big it should be compared to the body?the plane is about 13 inches long
lol by looking at my first diy plane i can understand what you mean vicman. my motor i believe is only a 380 i wonder if thats enough for a small about 13 inch plane
If you've ever seen what many RC Combat planes look like after a few rounds, you'd know that while wing shape does affect how the plane flys, it often affects it less than most people would think. same thing with the tail being out of alignment with the wing and all kind of other things. If you're trying to to build a pattern plane or something like that, it matters more, but for just flying around, you can get away with quite a lot.
