The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
Counterfeit Spektums ??
Old 12-05-2011, 06:06 AM
Edwin
Default Counterfeit Spektums ??
Just saw this on the spektrum web site.
Attention: Horizon Hobby has confirmed that all Spektrum Products being sold by KoKo Technology are counterfeit. We consider it a danger to use these products, waive all liability and will not support any warranty or service in regards to them.
I suppose it was only a matter of time.
Edwin
Found some more info.
http://www.federalregister.gov/artic...ontaining-same
Old 12-05-2011, 07:25 AM
flyinwalenda
flyinwalenda's Avatar
Default RE: Counterfeit Spektums ??
Well what do you expect buying from someone with a rubber nose, pointed hat, and big floppy shoes ?
Old 12-05-2011, 08:34 AM
topspin
Looks like Horizon took it to the system and got results. I have seen several clone and so called DSM2 compatible receivers from several Chinese vendors but have always been skeptical since I have seen several of the most popular knockoffs fail with catastrophic results. Score one for Horizon..
Old 12-06-2011, 05:17 PM
eddieC
eddieC's Avatar
" I have seen several of the most popular knockoffs fail with catastrophic results. Score one for Horizon.. "??Care to give some names? That would be important info.
Old 12-06-2011, 06:49 PM
rcdude7
My Feedback: (264)
Futaba has a big problem with counterfeit heli gyros also. I would venture to say that most of the NEW gyros listed on ebay are fakes.
Old 12-07-2011, 06:05 AM
on_your_six
I don't use the counterfeit Spektrum receivers, I know several that do... seem to work ok with DSM2 but problems with DSMX
Old 12-07-2011, 11:41 AM
Rodney
Do not confuse counterfeit with the so called knockoffs. By definition, a counterfeit is made to as closely resemble the original as possible and to be passed off as the original while what some call knockoffs are designs that work like the original but does not usually look like them nor are they advertised as the original. In many cases the knockoffs are as good or better than the originals and often a much better value for the dollar. There are many of the DSMxx designs which are quite acceptable in so far as performance goes and in some cases superior.
Old 12-10-2011, 07:50 AM
OldRookie
My Feedback: (13)
Counterfeiting Spektrum is like counterfeiting pennies....Why Bother?
Greg
Old 12-10-2011, 08:26 AM
jester_s1
Moderator
I was kinda thinking the same thing, OldRookie. Why not counterfeit a brand with a good reputation?
Old 12-10-2011, 10:16 AM
blikseme300
My Feedback: (118)
My thoughts exactly. Spektrum uses off the shelf components so it is wide open to be copied.
Bliksem
