Need 3/16" nose gear source
My Feedback: (27)
I can't find 3/16" size anywhere. I have the one pictured here but it's for 5/32" wire. I might be able to drill it out but I still need a couple more. I don't know who carries this one either. Any help would be great.
RE: Need 3/16
I had the same problem when I was setting up rudders on some float planes. I had two double tiller arms in my parts bins but couldn't find any more locally or in a US based online store. One had to be drilled out to 3/16 and it came out fine. Just go slow and drill it in steps.
I ended up making the others using wheel collars and double servo arms. It took some time but they are still holding up after 3 years.
I've seen 90 degree 3/16" bell crank type arms but no 180 degree arms in the states.
If you wanted to order 5mm ones from overseas I found this:
[link=http://www.cornwallmodelboats.co.uk/acatalog/tiller-arms.html]http://www.cornwallmodelboats.co.uk/acatalog/tiller-arms.html[/link]
My Feedback: (27)
RE: Need 3/16
Piper chuck-Thanks for the suggestion!
flyinwalinda-I appreciate the link, I didn't think about doing a search for tiller arms. I ended up using nose gear drilled out carefully..like you suggested.
