The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
30 oz/ sq ft
Old 09-03-2003, 09:52 PM
vtol_guy
Default 30 oz/ sq ft
thats the wing loading of my new toy
wingspan= 54 inches
chord= 12inches
weight= 8lb
put a lotta money into this model, removing weight is virtually impossible
any suggestions on what to do?
Old 09-04-2003, 01:29 AM
jwoolridge
Whats so bad about 30 oz/sq'. Would help to have more details on the plane. Type of plane, name, scale? and some pictures would help.
JAmes
Old 09-04-2003, 04:33 PM
vtol_guy
its my own creation
have posted pic so you get a better idea
i thought 23oz / sq ft was generally seen as the limit?
Old 09-04-2003, 04:46 PM
jwoolridge
For hand launch it may be a bit (how do I say it +) interesting
Try launching it from a dolly first. I have a lanier F4 prop jet and it's wing loading is 28oz/sq' I would not try to hand launch it in my right mind but it flies great just needs a lot of speed compared to a 40 size sport plane to take off. Lots of jet and large scale planes are over 50ozs/sq'. If I was you and youd flown a prop jet or something fats before I'd put it on a dolly and test fly it myself. If you haven't done that befrore let someone more expirienced test fly it.
About the dolly. I have heard of a few ways to make them but the way i'd do it is make it about 18" long. Build it with trike gear. Put in a spare receveir, servo and battery. Now you use the servo to run the nose wheel and plug it into the receiver rudder channel. If you have a rudder on the plane you'll have to be careful about how you set up the linkage because you can't reverse the rudder on the plane. If you dont have rudder just build the dolly and if you need to reverse the servo when your done from your tx on the rudder ch.
Hope all this helps
James
Old 09-04-2003, 04:52 PM
BasinBum
Actually, your wing loading is 28.444 oz per square ft.
Maybe replace that chair with some wheels?
Old 09-04-2003, 08:09 PM
vtol_guy
the pic aint of the finished product! geez, lol
its got the rear U/C on now and putting on the noseleg tommorow
28...30.....whats the difference??
Old 09-04-2003, 10:53 PM
BasinBum
2 oz.
Old 09-04-2003, 11:03 PM
Righty-RCU
it looks like someone did a bad job of giving it a paintjob with MS Paint.
Old 09-05-2003, 03:30 AM
Heavybird
Righty, I was thinkin' the same thing.
Does anyone else smell a fish?
Jake
Old 09-05-2003, 03:51 AM
BasinBum
Now that you mention it...
Vtol, are you a little troll?
Old 09-05-2003, 10:26 AM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Provided you have enough power, it will be FAST, that's all. There is no "fall out of the sky, won't ever fly at all" wing loading limit. I know someone with a few planes that have loadings over 40oz per square foot, and they fly.
What'd you build it out of, marine plywood and concrete?
Old 09-05-2003, 01:17 PM
Dave Matthews
Dave Matthews's Avatar
Location: out country, somewhere, US MINOR OUTLYING ISLANDS
You might need a wee bit of left hand aileron to offset the 2 totaly different thrust lines on the JPG. Plane . . . . . . .. . .
Next time make sure you 'paste' the engines in the same way . . .
GOOD ONE !!!!
Old 09-05-2003, 04:30 PM
vtol_guy
Default pic
ok the pic i put in was the wrong one (its the one i planned the colour scheme on) and yes i did copy and paste the engine because the pic i took only had one engine and it looked stupid :stupid:
plane is made of balsa, ply and foam and spruce
here is a pic of the latest it looks like, pic just been taken now
Old 09-05-2003, 04:33 PM
vtol_guy
and a second pic for all the people who think i made the plane out of computer pixels
Old 09-05-2003, 04:35 PM
vtol_guy
oh and yes IM AWARE THERE IS NO RUDDER, lol
just before you make another criticism, BB
Old 09-05-2003, 04:36 PM
J_R
Default Doug Powell's Bipe
How about this one
Old 09-05-2003, 05:04 PM
jwoolridge
I bet that bipe got some pretty good vertical.
Old 09-05-2003, 05:15 PM
J_R
I heard that when Doug ran the antenna out the back of the fuse, instead of along the wing, the CG changed by 5%
Old 09-05-2003, 05:22 PM
EagleOne
if you are going for a vertical takeoff/landing then I don't see any problem with the high wing loading, except that the stall speed isn't going to be as slow as a trainer's.......My main concern is with the thrust....The engines gotta have enough to pull it out of the ground at at least 3/4 throttle.......Other than that I see no problem....
Old 09-05-2003, 08:41 PM
vtol_guy
each engine produces 6lb each, for a 8lb model i'm saying its pretty good
