Oh my...i need some help...
Hey there. So i have only two "large" planes, and im now concerned. After reading about peoples fingers being chopped off from those props, im concerned. The precautions i take are:
I have a throttle cut programmed into my radio, and i keep that switch activated when the plane is powered up on the ground, during preflight checks.
I ALWAYS stand behind the plane, and keep clear from the prop.
When working on the plane, i NEVER have anything plugged in... i plug everything in when im done working on it, and i test it outside...not inside.
I ALWAYS plug the battery in from BEHIND the plane.
Thats all the precautions I've been taking from day 1, but im still worried about being bitten by a prop...any advice or comments on my precautions? I would absolutely hate to be bitten by one. Any other precautions i should take?
Also, sorry if this is the wrong section to post in. Couldn't find any other section.
Moderator
RE: Oh my...i need some help...
It sounds like your safety procedures are good. The main thing is to respect the prop and treat it like it could start at any moment when the battery is plugged in, even if you do have a throttle kill switch.
Thanks guys. Yeah i will make sure not to become careless...heck, i still monitor my lipos by sitting right next to them the whole time. Anyone else want to share their opinions?
My Feedback: (66)
SC
It's not only the big planes/engines that will take a finger. I lost mine to a Saito 130...a small twin. I stumbled on a piece of plywood under my tuning table. Right hand, index finger, first joint....stupid hurts[:@]
Okay thank you guys. Whenever im working on the plane though, I have nothing plugged in, and then when im setting it up, its usually not plugged in. I only plug it in really right before flying.
VT
From a boss a long time ago at a manufacturing facility(Cleaned up for RCU), never place your fingers in anyplace where you wouldn't place your "manhood". Yes, I still have 10 fingers.
VA
ORIGINAL: Lamoilleriver
From a boss a long time ago at a manufacturing facility(Cleaned up for RCU), never place your fingers in anyplace where you wouldn't place your ''manhood''. Yes, I still have 10 fingers.
LOL.... I still have the scars on my right hand from a 10 inch APC prop 10 years ago and it was only connected to a geared 400 brushed mortor. I got five stiches on the back of my hand and learned that even electric planes can hurt you.[X(]
