POLL: Cabinaire Vs Fairchild 24
CT
I dont know if these will be RC or Rubber Power but here goes. heres the deal, I dont know which to build first and I am ready to go on these. So I am taking a poll and you get to vote....see?...You will finally be able to tell me what to do.. I knew I could keep the scoring going somehow okay what do you suggest I build first?
CT
RE: POLL: Cabinaire Vs Fairchild 24
Well...I got plenty of responses here[:'(]......Thanks Lightfoot and Chook ...The Fairchild Gets built first. I will post pics in the Kit building Forum when available.
AZ
Before you get too deep into the Cabinaire or the Fairchild take a close look at the Curtiss Robin. It has all the good stuff in Joe Nieto's plans including scale structure. It was made of welded tubing and stamped aluminum ribs. It could be built with scale construction and still be an easy aircraft. Two choices of scale engines, in-line and radial. Same Airplane that Doug Corrigan flew "wrong way" to Ireland in the 30's. the design is very much like one of today's trainers EG: Sig Kadet Senior with ailerons and struts.
