Paragraphs
Paragraphs
OK, I just got a new computer.When I draft a posting or reply I can lay out all my text and form my paragraphs and all looks fine.But when I post it and re-read it, all the text is jammed together and no separate paragraphs. What's up???Peter H.
RE: Paragraphs
Hi Ken,Above is a perfect example and this will be too. My signature was placed at the bottom along with this new sentence. Peter H.
RCU Forum Manager/Admin
My Feedback: (9)
RE: Paragraphs
Peter,
Ok, it sounds like you're not loading the full editor completely. I've seen this happen before. First thing is to go into your RCU settings (yellow button bar at the top of the screen, click the settings button). Then scroll all the way down to the last setting "Editor". Even if it's set to HTML Editor select the "Older BBstyle Editor" and select ok at the bottom of the screen. The go back to the settings and change the editor back to the HTML editor.
If this still won't work with for you it's probably a setting in your browser that is blocking out the editor script from fully loading. Which browser are you using?? have you tried in a different browser to see if it works properly.
Ken
