New & need help!!
New & need help!!
Hi, i have a skytec wasp x3 rc heli and need some help!
When i plug in the battery it makes a beeping noise, and won't connect with the controller. It beeps twice, "beep..............Beep' and then repeats. It has no info about it in the manual which is awfull BTW! so anyone with so knowledge would be greatly appretiated!
Moderator
RE: New & need help!!
It seems you need to bind the controller to the heli again. Press the code button on the reciver first avter turning it on for 4 to 6 seconds, or until it flashes fast. Let go, and it should work.
Hi, i just 1) turned the controller on, 2) plugged in the battery and 3) pushed and held the pairing button and nothing happend at all. It just continued beeping throughout.
Anoymore suggestions?
