The Clubhouse If it doesn't fit in any other category and is about general RC stuff then post it here at the Clubhouse.
How do I make my plane produce smoke as an airiel effect
Reply
Old 08-12-2013, 09:06 PM
rmbc714@yahoo.com
rmbc714@yahoo.com's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How do I make my plane produce smoke as an airiel effect
I am building a Jack Stafford B24 Liberator with 4 HP .20 Engines. I would like to be able to make smoke trails at will and I don't know how to do this. Could someone tell me how I can accomplish this. Thank You
rmbc714@yahoo.com is offline
Old 08-13-2013, 05:48 AM
AMA 74894
Moderator
AMA 74894's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several ways of accomplishing that, although the simplest for small IC engines would likely be simply pumping oil into the exhaust.
http://shop.dubro.com/c/aircraft_smoke-systems
Pyrotechnics are possible too, although they can not be turned OFF, they simply burn out.
http://www.rcuniverse.com/magazine/a...article_id=215
AMA 74894 is offline
Old 08-14-2013, 05:16 PM
stick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To get good smoke with small 2 stroke glow engines you will need to preheat the oil before it goes into the muffler. Most smoke mufflers have an internal coil of tubing inside the muffler that the oil flows through before it is released into the exhaust. I have seen brass tubing wrapped around the outside of a stock muffler to preheat the oil with good results. You will also need a smoke "Pump" to move the oil to the muffler.
stick is offline
Old 08-14-2013, 06:19 PM
karlik
karlik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a couple of puffed up lipos I'll sell ya real cheap
karlik is offline
Old 08-14-2013, 06:26 PM
DavidAgar
DavidAgar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The smoke oil will work, but it has to be really pre heated with the smaller engines. You are going to need to plan the plumbing as you build the plane and have the pump and oil tank somewhere in the fuse. You are also going to need a high capacity battery for the pump. Gonna take some planning, so keep us posted on your progress. Good Luck, Dave
DavidAgar is offline
Old 01-19-2014, 10:25 AM
rmbc714@yahoo.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a good one, I like that. I have a lipo outside right now that is ballooning. Thanks for the laugh.
Old 01-19-2014, 10:30 AM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pre-heating the oil is no big deal, an easy task. Just wrap 2-4 coils of brass tubing around the exhaust header as I have done in the pic.
acerc is offline
Reply
Display Modes
